- To: cgal <>
- Subject: RE: [cgal-discuss] Triangulation_3 input
- Date: Sun, 23 Nov 2008 18:20:06 +0000
- Importance: Normal
Hello, thank you for your reply. I ran the code you provided. I found out that, in release build it runs fine, In debug build however, it gives the error I mentioned earlier. Is this normal behaviour? If so, is there any way around it? Not being able to run in debug with this part of the code would be cumbersome. Thanks, Peter. From: To: Date: Sun, 23 Nov 2008 17:17:11 +0100 Subject: Re: [cgal-discuss] Triangulation_3 input This is the empty ball condition used for defining the Delaunay triangulation. When inserting a new point p, all simplices S such that p is inside the circumsphere of S are searched. This is the test side_of_oriented_sphere. At the beginning, the method checks if the four vertices of simplex S are oriented positively. This should not fail with a Filtered kernel. No, this reason would be valid if you were using an unfiltered kernel.
I copy pasted your definitions (see code below), and I am unable to reproduce your problem. The program prints:
triangulation of 10000 points computed in 1.56 s
Are you sure you are really using these definitions?
Camille
#include <CGAL/point_generators_3.h>
#include <CGAL/copy_n.h>
#include <list>
// YOUR DEFINITIONS START HERE
#include <CGAL/Simple_cartesian.h>
#include <CGAL/Filtered_kernel.h>
typedef CGAL::Filtered_kernel<CGAL::Simple_cartesian<float> > KernelFloat;
typedef CGAL::Exact_predicates_inexact_constructions_kernel KernelDouble;
typedef KernelFloat KernelActive;
#include <CGAL/Delaunay_triangulation_3.h>
#include <CGAL/Triangulation_hierarchy_3.h>
typedef CGAL::Triangulation_vertex_base_3<KernelActive> TVB;
typedef CGAL::Triangulation_hierarchy_vertex_base_3<TVB> THVB;
typedef CGAL::Triangulation_data_structure_3<THVB> TDS;
typedef CGAL::Delaunay_triangulation_3<KernelActive, TDS> DT;
typedef CGAL::Triangulation_hierarchy_3<DT> CGAL_Triangulation;
typedef CGAL_Triangulation::Point CGAL_Point;
typedef CGAL_Triangulation::Vertex_handle CGAL_VertexHandle;
typedef CGAL_Triangulation::Finite_vertices_iterator CGAL_FiniteVerticesIter;
typedef CGAL_Triangulation::Cell_handle CGAL_CellHandle;
// YOUR DEFINITIONS END HERE
#include <boost/progress.hpp>
#include <iostream>
#define N 10000
int main() {
CGAL_Triangulation triangulation;
typedef CGAL::Random_points_on_sphere_3<CGAL_Point> Generator;
std::list<CGAL_Point> collection;
CGAL::copy_n(Generator(1.), N, std::back_inserter(collection));
std::cout << "triangulation of " << N << " points computed in ";
boost::progress_timer timer(std::cout);
triangulation.insert(collection.begin(), collection.end());
return 0;
De nieuwe Hotmail maakt je leven nog makkelijker Wees er als eerste bij. |
- [cgal-discuss] Triangulation_3 input, pgoeleven, 11/23/2008
- Re: [cgal-discuss] Triangulation_3 input, Camille Wormser, 11/23/2008
- RE: [cgal-discuss] Triangulation_3 input, pgoeleven, 11/23/2008
- Re: [cgal-discuss] Triangulation_3 input, Olivier Devillers, 11/23/2008
