- To:
- Subject: Re: [cgal-discuss] CGAL and valgrind
- Date: Fri, 28 Nov 2008 16:21:22 +0100
Hi all,
I am very happy to give any information you need to solve the problem (and am
quite sure that in the end I did something wrong somewhere). Here is what I am
trying to do:
1. Make a polyhedron
2. Delete all halfedges that separate facets that are in one plane
- check if the facet halfedge->facet() and halfedge->opposite()->facet() are
coplanar
- if they are, use join_facet(halfedge) to delete the corresponding edge and
therewith merge the two facets
3. Retriangulate the polyhedron so that each facet is a triangle
all of that using:
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
(me and Gmpq do not work together very well so I try with doubles)
This works OUTSIDE of valgrind only if the polyhedra are cubes. If they are
anything else, it works only INSIDE of valgrind.
If I start the program OUTSIDE of valgrind, it stops with:
CGAL error: precondition violation!
Expr: circulator_size(h->vertex_begin()) >= size_type(3)
File: /home/jkbecker/Code/eKolos/src/eKolos/core/aPolyhedron_3.h
Line: 1196
Explanation:
terminate called after throwing an instance of 'CGAL::Precondition_exception'
what(): CGAL ERROR: precondition violation!
Line: 1196
CGAL probably produces antennas and at a later stage bails out because of it.
INSIDE of valgrind, it works fine.
The polyhedra check out ok using p.is_valid(), they fail the higher tests
(p.is_valid(true,1)), but I am not sure about the real meaning of this yet (I
will send output if needed).
Any ideas? Let me know if you need more info.
Jens
jkbecker@tiny:~$
gcc -v
Using built-in specs.
Target: i486-linux-gnu
Configured with: ../src/configure -v
--enable-languages=c,c++,fortran,objc,obj-c++,treelang --prefix=/usr
--enable-shared --with-system-zlib --libexecdir=/usr/lib
--without-included-gettext --enable-threads=posix --enable-nls
--with-gxx-include-dir=/usr/include/c++/4.2 --program-suffix=-4.2
--enable-clocale=gnu --enable-libstdcxx-debug --enable-objc-gc --enable-mpfr
--enable-targets=all --enable-checking=release --build=i486-linux-gnu
--host=i486-linux-gnu --target=i486-linux-gnu
Thread model: posix
gcc version 4.2.4 (Ubuntu 4.2.4-1ubuntu3)
Dr. J.K. Becker
University of Tuebingen - Institute for Geoscience
Sigwartst. 10 - 72076 Tuebingen (Germany)
Tel.: ++49 7071 29 73139 Fax: +49 7071 5059
web: http://www.jkbecker.de
Quoting Sylvain Pion
Laurent Rineau wrote:
On Friday 28 November 2008 14:17:06 Sylvain Pion wrote:
Jens K. Becker wrote:
The program compiles fine but does
not work (it always crashes when trying to remove halfedges (using
join_facets). If I run it in valgrind, it perfectly works.
Valgrind does not emulate FPU rounding modes which are used to implement
interval arithmetic. The later being used in filtered kernels which you
can find in many places in CGAL. A solution is to used either inexact
fast non-robust, risky, use-at-your-own-risk, may-or-may-not-work-for-you
kernels e.g. Simple_cartesian<double>, or a slow exact kernel, e.g.
Simple_cartesian<Gmpq>. That may be enough for debugging.
The ideal solution would be to ping the valgrind developers (again),
so that they work on supporting this missing feature.
Sylvain, you missed a point: Jens program works only *IN* valgrind, and *that* is strange. What sort of CGAL can work only if rounding mode are never changed?
OK, then I guess we need more details about "does not work".
But valgrind is quite bad at emulating the FPU. For example I think
it emulates 64-bit only FPU instructions, so it truncates the additional
precision on x86. This can affect the result, in which ever direction.
Similarly, not emulating the rounding mode makes all intervals singleton,
which prevents any filter failure, hence no costly computation, and so
might make a program look like it works whereas the too costly computations
might kill it for performance/memory reasons.
Again, more details are needed, but my gut feeling is that it's most
probably something around this problem.
Sylvain Pion
INRIA Sophia-Antipolis
Geometrica Project-Team
CGAL, http://cgal.org/
- [cgal-discuss] Error with natural_neighbor_coordinates_2, David Reis, 11/28/2008
- [cgal-discuss] CGAL and valgrind, Jens K. Becker, 11/28/2008
- Re: [cgal-discuss] CGAL and valgrind, Sylvain Pion, 11/28/2008
- Re: [cgal-discuss] CGAL and valgrind, Laurent Rineau, 11/28/2008
- Re: [cgal-discuss] CGAL and valgrind, Jens K. Becker, 11/28/2008
- Re: [cgal-discuss] CGAL and valgrind, Sylvain Pion, 11/30/2008
- Re: [cgal-discuss] CGAL and valgrind, Bernd Gaertner, 11/29/2008
