- To:
- Subject: Re: [cgal-discuss] Spectral Decomposition
- Date: Sat, 29 Nov 2008 18:48:31 +0530
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:in-reply-to:mime-version :content-type:references; b=kZd6F0PJW6048x+vYMJ6ARhSc64gBW+0cpD15BroeLc63A5jAHpvQv47UUSylq8wlK 4RTHQnOZ5R9PXbMQVXmgnbvPQdr/DjkiVm2UydZeidp3aV1yhecp1eG+30ZLQOHB4aYi XSiAZIxLkuoiJJP2309W6zQvgG3B3Hj2ojqYI=
On Sat, Nov 29, 2008 at 6:30 PM, Pierre Alliez <> wrote:
hi Poona,
you are right arpack++ is really tricky to compile but I managed to get it to work last year using Visual 2003 and the Intel FORTRAN compiler + TAUCS for the reverse interface (you can use SuperLu though).
best,
Pierre
Chaman Singh Verma a écrit :--
Hello,
I am interested in first 100 eigenvalues of a laplacian matrix (arising from 3D triangulated surface to
extract Morse-Simplices). Although I have googled a lot, I couldn't get any good package to this job.
Lapack and Scalapack work for dense matrices and give full spectrum, Arpack++ is buggy and not
compiled with modern compilers.
Any suggestion for robust and reliable modules which is capable of extracting few minimum eigenvalues
from a laplacian matrix will be a great help.
Thanks.
csv
Poona, India
Pierre Alliez
INRIA Sophia Antipolis - Mediterranee Project-team GEOMETRICA http://www-sop.inria.fr/members/Pierre.Alliez/
Tel: +33 4 92 38 76 77
Fax: +33 4 97 15 53 95
Hi,
I don't know if SuperLU can be used to extract few eigenvalues. Is it possible ?
Arpack++ is based on pretty old compilers and despite my hard work, modifying
templates became a big headache.
Thanks.
Chaman Singh
- [cgal-discuss] Spectral Decomposition, Chaman Singh Verma, 11/28/2008
- Re: [cgal-discuss] Spectral Decomposition, Pierre Alliez, 11/29/2008
- Re: [cgal-discuss] Spectral Decomposition, Chaman Singh Verma, 11/29/2008
- Re: [cgal-discuss] Spectral Decomposition, Pierre Alliez, 11/30/2008
- Re: [cgal-discuss] Spectral Decomposition, Chaman Singh Verma, 11/30/2008
