- To:
- Subject: Re: [cgal-discuss] Spectral Decomposition
- Date: Sat, 29 Nov 2008 14:00:50 +0100
- Organization: INRIA
hi Poona,
you are right arpack++ is really tricky to compile but I managed to get it to work last year using Visual 2003 and the Intel FORTRAN compiler + TAUCS for the reverse interface (you can use SuperLu though).
best,
Pierre
Chaman Singh Verma a écrit :
Hello,
I am interested in first 100 eigenvalues of a laplacian matrix (arising from 3D triangulated surface to
extract Morse-Simplices). Although I have googled a lot, I couldn't get any good package to this job.
Lapack and Scalapack work for dense matrices and give full spectrum, Arpack++ is buggy and not
compiled with modern compilers.
Any suggestion for robust and reliable modules which is capable of extracting few minimum eigenvalues
from a laplacian matrix will be a great help.
Thanks.
csv
Poona, India
Pierre Alliez
INRIA Sophia Antipolis - Mediterranee Project-team GEOMETRICA http://www-sop.inria.fr/members/Pierre.Alliez/
Tel: +33 4 92 38 76 77
Fax: +33 4 97 15 53 95
- [cgal-discuss] Spectral Decomposition, Chaman Singh Verma, 11/28/2008
- Re: [cgal-discuss] Spectral Decomposition, Pierre Alliez, 11/29/2008
- Re: [cgal-discuss] Spectral Decomposition, Chaman Singh Verma, 11/29/2008
- Re: [cgal-discuss] Spectral Decomposition, Pierre Alliez, 11/30/2008
- Re: [cgal-discuss] Spectral Decomposition, Chaman Singh Verma, 11/30/2008
