- To:
- Subject: Re: [cgal-discuss] CGAL and valgrind
- Date: Sun, 30 Nov 2008 20:32:44 -0800
Stepping back from the geometric problem, if your code does execute
correctly in under valgrid this is generally symptomatic of a memory
management error. It is also possible, I suppose, that you have
different compiler settings between the valgrid build and the build
that is executed and fails, although that is most likely not the
problem at least in my experience.
-Sebastian.
On Fri, Nov 28, 2008 at 7:21 AM, Jens K. Becker
wrote:
> Hi all,
> I am very happy to give any information you need to solve the problem (and
> am
> quite sure that in the end I did something wrong somewhere). Here is what I
> am
> trying to do:
> 1. Make a polyhedron
> 2. Delete all halfedges that separate facets that are in one plane
> - check if the facet halfedge->facet() and halfedge->opposite()->facet()
> are
> coplanar
> - if they are, use join_facet(halfedge) to delete the corresponding edge
> and
> therewith merge the two facets
> 3. Retriangulate the polyhedron so that each facet is a triangle
> all of that using:
> typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
> (me and Gmpq do not work together very well so I try with doubles)
> This works OUTSIDE of valgrind only if the polyhedra are cubes. If they are
> anything else, it works only INSIDE of valgrind.
> If I start the program OUTSIDE of valgrind, it stops with:
> CGAL error: precondition violation!
> Expr: circulator_size(h->vertex_begin()) >= size_type(3)
> File: /home/jkbecker/Code/eKolos/src/eKolos/core/aPolyhedron_3.h
> Line: 1196
> Explanation:
> terminate called after throwing an instance of
> 'CGAL::Precondition_exception'
> what(): CGAL ERROR: precondition violation!
> Line: 1196
> CGAL probably produces antennas and at a later stage bails out because of
> it.
> INSIDE of valgrind, it works fine.
> The polyhedra check out ok using p.is_valid(), they fail the higher tests
> (p.is_valid(true,1)), but I am not sure about the real meaning of this yet
> (I
> will send output if needed).
> Any ideas? Let me know if you need more info.
> Jens
> jkbecker@tiny:~$
> gcc -v
> Using built-in specs.
> Target: i486-linux-gnu
> Configured with: ../src/configure -v
> --enable-languages=c,c++,fortran,objc,obj-c++,treelang --prefix=/usr
> --enable-shared --with-system-zlib --libexecdir=/usr/lib
> --without-included-gettext --enable-threads=posix --enable-nls
> --with-gxx-include-dir=/usr/include/c++/4.2 --program-suffix=-4.2
> --enable-clocale=gnu --enable-libstdcxx-debug --enable-objc-gc --enable-mpfr
> --enable-targets=all --enable-checking=release --build=i486-linux-gnu
> --host=i486-linux-gnu --target=i486-linux-gnu
> Thread model: posix
> gcc version 4.2.4 (Ubuntu 4.2.4-1ubuntu3)
> Dr. J.K. Becker
> University of Tuebingen - Institute for Geoscience
> Sigwartst. 10 - 72076 Tuebingen (Germany)
> Tel.: ++49 7071 29 73139 Fax: +49 7071 5059
> web: http://www.jkbecker.de
> Quoting Sylvain Pion
>> Laurent Rineau wrote:
>>> On Friday 28 November 2008 14:17:06 Sylvain Pion wrote:
>>>> Jens K. Becker wrote:
>>>>> The program compiles fine but does
>>>>> not work (it always crashes when trying to remove halfedges (using
>>>>> join_facets). If I run it in valgrind, it perfectly works.
>>>> Valgrind does not emulate FPU rounding modes which are used to implement
>>>> interval arithmetic. The later being used in filtered kernels which you
>>>> can find in many places in CGAL. A solution is to used either inexact
>>>> fast non-robust, risky, use-at-your-own-risk,
>>>> may-or-may-not-work-for-you
>>>> kernels e.g. Simple_cartesian<double>, or a slow exact kernel, e.g.
>>>> Simple_cartesian<Gmpq>. That may be enough for debugging.
>>>> The ideal solution would be to ping the valgrind developers (again),
>>>> so that they work on supporting this missing feature.
>>> Sylvain, you missed a point: Jens program works only *IN* valgrind, and
>>> *that* is strange. What sort of CGAL can work only if rounding mode are
>>> never changed?
>> OK, then I guess we need more details about "does not work".
>> But valgrind is quite bad at emulating the FPU. For example I think
>> it emulates 64-bit only FPU instructions, so it truncates the additional
>> precision on x86. This can affect the result, in which ever direction.
>> Similarly, not emulating the rounding mode makes all intervals singleton,
>> which prevents any filter failure, hence no costly computation, and so
>> might make a program look like it works whereas the too costly
>> computations
>> might kill it for performance/memory reasons.
>> Again, more details are needed, but my gut feeling is that it's most
>> probably something around this problem.
>> Sylvain Pion
>> INRIA Sophia-Antipolis
>> Geometrica Project-Team
>> CGAL, http://cgal.org/
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
Sebastian Marino
Chief Software Architect
Makani Power, Inc., Alameda, Ca.
www.makanipower.com
510.387.8077
- Re: [cgal-discuss] CGAL and valgrind, Sebastian Marino, 12/01/2008
- Re: [cgal-discuss] CGAL and valgrind, Jens K. Becker, 12/01/2008
- Re: [cgal-discuss] CGAL and valgrind, Jens K. Becker, 12/02/2008
