- To:
- Subject: Re: [cgal-discuss] CGAL and valgrind
- Date: Mon, 1 Dec 2008 09:19:16 +0100
Hi all,
I did try out the code on 2 different machines over the weekend:
1. machine: Older version of CGAl and Linux (32-bit Ubuntu): Same errors
2. machine: Same version of CGAL and Linux but this time 64-bit Ubuntu: works
flawlessly.
So I guess it has got nothing to do with the code itself but with internals of
the respective Linux (Ubuntu?) version, as Sebastian wrote. It is still a
strange thing, but there is not really anything I can do about it. If some of
you are interested in this problem, let me know and I can give you all the info
you may need. I myself will not go into it, I am just happy that it works.
Sylvain, I had problems with construction of things before and never really
understood what the problem is. Therefore, I wrote my own checks for these (and
other things such as angle between facets, plane normal, halfedge length etc.).
I dont mind to do that since it is only standard math and easy enough to write
(thanks to the clever design of teh hds, I really like it), but I never
understood why my checks work and are stable while the build-in checks from
CGAL have problems (using double as a number type). Granted, my
checks/functions are probably not mathematically precise and I have to do some
extra checks (e.g. if the calculated cosine is <=1, it sometimes is 1.000000002
due to rounding), but they work good enough for me (and I suspect would be good
enough for other people using doubles).
Thanks for your help and suggestions,
Jens
Dr. J.K. Becker
University of Tuebingen - Institute for Geoscience
Sigwartst. 10 - 72076 Tuebingen (Germany)
Tel.: ++49 7071 29 73139 Fax: +49 7071 5059
web: http://www.jkbecker.de
Quoting Sebastian Marino
Stepping back from the geometric problem, if your code does execute
correctly in under valgrid this is generally symptomatic of a memory
management error. It is also possible, I suppose, that you have
different compiler settings between the valgrid build and the build
that is executed and fails, although that is most likely not the
problem at least in my experience.
-Sebastian.
On Fri, Nov 28, 2008 at 7:21 AM, Jens K. Becker
wrote:
Hi all,
I am very happy to give any information you need to solve the problem (and
am
quite sure that in the end I did something wrong somewhere). Here is what I
am
trying to do:
1. Make a polyhedron
2. Delete all halfedges that separate facets that are in one plane
- check if the facet halfedge->facet() and halfedge->opposite()->facet()
are
coplanar
- if they are, use join_facet(halfedge) to delete the corresponding edge
and
therewith merge the two facets
3. Retriangulate the polyhedron so that each facet is a triangle
all of that using:
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
(me and Gmpq do not work together very well so I try with doubles)
This works OUTSIDE of valgrind only if the polyhedra are cubes. If they are
anything else, it works only INSIDE of valgrind.
If I start the program OUTSIDE of valgrind, it stops with:
CGAL error: precondition violation!
Expr: circulator_size(h->vertex_begin()) >= size_type(3)
File: /home/jkbecker/Code/eKolos/src/eKolos/core/aPolyhedron_3.h
Line: 1196
Explanation:
terminate called after throwing an instance of
'CGAL::Precondition_exception'
what(): CGAL ERROR: precondition violation!
Line: 1196
CGAL probably produces antennas and at a later stage bails out because of
it.
INSIDE of valgrind, it works fine.
The polyhedra check out ok using p.is_valid(), they fail the higher tests
(p.is_valid(true,1)), but I am not sure about the real meaning of this yet
(I
will send output if needed).
Any ideas? Let me know if you need more info.
Jens
jkbecker@tiny:~$
gcc -v
Using built-in specs.
Target: i486-linux-gnu
Configured with: ../src/configure -v
--enable-languages=c,c++,fortran,objc,obj-c++,treelang --prefix=/usr
--enable-shared --with-system-zlib --libexecdir=/usr/lib
--without-included-gettext --enable-threads=posix --enable-nls
--with-gxx-include-dir=/usr/include/c++/4.2 --program-suffix=-4.2
--enable-clocale=gnu --enable-libstdcxx-debug --enable-objc-gc --enable-mpfr
--enable-targets=all --enable-checking=release --build=i486-linux-gnu
--host=i486-linux-gnu --target=i486-linux-gnu
Thread model: posix
gcc version 4.2.4 (Ubuntu 4.2.4-1ubuntu3)
Dr. J.K. Becker
Quoting Sylvain Pion
Laurent Rineau wrote:
On Friday 28 November 2008 14:17:06 Sylvain Pion wrote:
Jens K. Becker wrote:
The program compiles fine but does
not work (it always crashes when trying to remove halfedges (using
join_facets). If I run it in valgrind, it perfectly works.
Valgrind does not emulate FPU rounding modes which are used to implement
interval arithmetic. The later being used in filtered kernels which you
can find in many places in CGAL. A solution is to used either inexact
fast non-robust, risky, use-at-your-own-risk,
may-or-may-not-work-for-you
kernels e.g. Simple_cartesian<double>, or a slow exact kernel, e.g.
Simple_cartesian<Gmpq>. That may be enough for debugging.
The ideal solution would be to ping the valgrind developers (again),
so that they work on supporting this missing feature.
Sylvain, you missed a point: Jens program works only *IN* valgrind, and
*that* is strange. What sort of CGAL can work only if rounding mode are
never changed?
OK, then I guess we need more details about "does not work".
But valgrind is quite bad at emulating the FPU. For example I think
it emulates 64-bit only FPU instructions, so it truncates the additional
precision on x86. This can affect the result, in which ever direction.
Similarly, not emulating the rounding mode makes all intervals singleton,
which prevents any filter failure, hence no costly computation, and so
might make a program look like it works whereas the too costly
computations
might kill it for performance/memory reasons.
Again, more details are needed, but my gut feeling is that it's most
probably something around this problem.
Sylvain Pion
INRIA Sophia-Antipolis
Geometrica Project-Team
CGAL, http://cgal.org/
Sebastian Marino
Chief Software Architect
Makani Power, Inc., Alameda, Ca.
www.makanipower.com
510.387.8077
- Re: [cgal-discuss] CGAL and valgrind, Sebastian Marino, 12/01/2008
- Re: [cgal-discuss] CGAL and valgrind, Jens K. Becker, 12/01/2008
- Re: [cgal-discuss] CGAL and valgrind, Jens K. Becker, 12/02/2008
