- To:
- Subject: Re: [cgal-discuss] How to read Polyhedron from .obj file and output
- Date: Fri, 05 Dec 2008 09:19:40 +0100
- Organization: INRIA
Hi wangk0705,
you can always use the incremental builder to do the job.
I attach an old piece of code that did the job a few years ago - just replace enriched_polyhedron with yours and adapt it according to the structure of your obj file. Also, it is better to use STL for file reading.
Usage:
Parser_obj<Kernel,Items> parser;
parser.read(filename,pMesh);
Pierre
Pierre Alliez
INRIA Sophia Antipolis - Mediterranee http://www-sop.inria.fr/members/Pierre.Alliez/
a écrit :
as the title,how to read in the Polyhedron from an existing .obj file and
output it after subdivision please?
I konw that output could be done through File_writer_wavefront
but is there any method of reading it?
if not,how to build a Polyhedron by reading in the obj file please?Is there
any
code provided?
thanks very much!
#include <CGAL/Polyhedron_incremental_builder_3.h>
#include "Enriched_polyhedron.h"
template <class HDS>
class Builder_obj : public CGAL::Modifier_base<HDS>
private:
typedef typename HDS::Vertex::Point Point;
typedef typename CGAL::Polyhedron_incremental_builder_3<HDS> Builder;
FILE *m_pFile;
public:
Builder_obj(FILE *pFile)
m_pFile = pFile;
~Builder_obj() {}
void operator()(HDS& hds)
Builder builder(hds,true);
builder.begin_surface(3,1,6);
read_vertices(builder);
read_facets(builder);
builder.end_surface();
private:
// read vertex coordinates
void read_vertices(Builder &builder)
fseek(m_pFile,0,SEEK_SET);
char pLine[512];
while(fgets(pLine,512,m_pFile))
if(pLine[0] == 'v')
float x,y,z;
if(sscanf(pLine,"v %f %f %f",&x,&y,&z) == 3)
builder.add_vertex(Point(x,y,z));
// read facets and uv coordinates per halfedge
void read_facets(Builder &builder)
char pLine[512];
char *pTmp = pLine;
if(pTmp[0] == 'f')
int index,n;
char index_ascii[512],n_ascii[512];
// create facet
builder.begin_facet();
pTmp += 2; // jump after 'f '
if(strstr(pTmp,"//"))
while(sscanf(pTmp,"%d//%d",&index,&n))
itoa(index,index_ascii,10);
itoa(n,n_ascii,10);
builder.add_vertex_to_facet(index-1);
pTmp += (2 +
strlen(index_ascii) + strlen(n_ascii));
if(strlen(pTmp) < 3)
break;
else
pTmp += 1;
else
while(sscanf(pTmp,"%d",&index))
pTmp += strlen(index_ascii);
break;
else
pTmp += 1;
builder.end_facet();
template <class kernel, class items>
class Parser_obj
public:
typedef typename Enriched_polyhedron<kernel,items>::HalfedgeDS HalfedgeDS;
Parser_obj() {}
~Parser_obj() {}
public:
bool read(const char*pFilename,
Enriched_polyhedron<kernel,items> *pMesh)
CGAL_assertion(pMesh != NULL);
FILE *pFile = fopen(pFilename,"rt");
if(pFile == NULL)
return false;
Builder_obj<HalfedgeDS> builder(pFile);
pMesh->delegate(builder);
fclose(pFile);
return true;
- [cgal-discuss] How to read Polyhedron from .obj file and output it after subdivision, wangk0705, 12/05/2008
- Re: [cgal-discuss] How to read Polyhedron from .obj file and output, Pierre Alliez, 12/05/2008
- Re: [cgal-discuss] How to read Polyhedron from .obj file and output, Kye Wong, 12/06/2008
