cgal-discuss - Re: [cgal-discuss] How to read Polyhedron from .obj file and output
  • To:
  • Subject: Re: [cgal-discuss] How to read Polyhedron from .obj file and output
  • Date: Sat, 6 Dec 2008 09:27:25 +0800
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:in-reply-to:mime-version :content-type:references; b=uYt2y0gkP0rnImwGiGUyLipts3hTu0SuBT2g8Wr/yY6wtup/xmanj1AXfsH/T5IRmN ztQeQn/O9TKgbTbVOj6FdJvuaLLobIXLu8CcA9Lt/pZJh1wGR1ZUchtfsaDJcAjn2CKs pBBcbVCWY4KW2XS2G9YXuDwRfmRgD3p/qfZpo=
Thanks very much for your sharing!
It's very helpful for me!
On Fri, Dec 5, 2008 at 4:19 PM, Pierre Alliez <> wrote:
Hi wangk0705,
you can always use the incremental builder to do the job.
I attach an old piece of code that did the job a few years ago - just replace enriched_polyhedron with yours and adapt it according to the structure of your obj file. Also, it is better to use STL for file reading.
Usage:
          Parser_obj<Kernel,Items> parser;
          parser.read(filename,pMesh);
Pierre
Pierre Alliez
INRIA Sophia Antipolis - Mediterranee http://www-sop.inria.fr/members/Pierre.Alliez/
a écrit :
as the title,how to read in the Polyhedron from an existing .obj file and
output it after subdivision please?
I konw that output could be done through File_writer_wavefront
but is there any method of reading it?
if not,how to build a Polyhedron by reading in the obj file please?Is there any
code provided?
thanks very much!
#include <CGAL/Polyhedron_incremental_builder_3.h>
#include "Enriched_polyhedron.h"
template <class HDS>
class Builder_obj : public CGAL::Modifier_base<HDS>
private:
       typedef typename HDS::Vertex::Point Point;
 typedef typename CGAL::Polyhedron_incremental_builder_3<HDS> Builder;
 FILE *m_pFile;
public:
 Builder_obj(FILE *pFile)
   m_pFile = pFile;
       ~Builder_obj() {}
 void operator()(HDS& hds)
   Builder builder(hds,true);
   builder.begin_surface(3,1,6);
                       read_vertices(builder);
     read_facets(builder);
   builder.end_surface();
private:
 // read vertex coordinates
 void read_vertices(Builder &builder)
   fseek(m_pFile,0,SEEK_SET);
       char pLine[512];
       while(fgets(pLine,512,m_pFile))
               if(pLine[0] == 'v')
       float x,y,z;
                       if(sscanf(pLine,"v %f %f %f",&x,&y,&z) == 3)
                                       builder.add_vertex(Point(x,y,z));
 // read facets and uv coordinates per halfedge
 void read_facets(Builder &builder)
       char pLine[512];
               char *pTmp = pLine;
               if(pTmp[0] == 'f')
                               int index,n;
                               char index_ascii[512],n_ascii[512];
       // create facet
       builder.begin_facet();
                               pTmp += 2; // jump after 'f '
                               if(strstr(pTmp,"//"))
                                       while(sscanf(pTmp,"%d//%d",&index,&n))
                                               itoa(index,index_ascii,10);
                                               itoa(n,n_ascii,10);
                       builder.add_vertex_to_facet(index-1);
                                               pTmp += (2 + strlen(index_ascii) + strlen(n_ascii));
                                               if(strlen(pTmp) < 3)
                                                       break;
                                               else
                                                       pTmp += 1;
                               else
                                       while(sscanf(pTmp,"%d",&index))
                                               pTmp += strlen(index_ascii);
                                                       break;
                                               else
                                                       pTmp += 1;
       builder.end_facet();
template <class kernel, class   items>
class Parser_obj
public:
   typedef typename Enriched_polyhedron<kernel,items>::HalfedgeDS HalfedgeDS;
   Parser_obj() {}
   ~Parser_obj() {}
public:
   bool read(const char*pFilename,
                               Enriched_polyhedron<kernel,items> *pMesh)
     CGAL_assertion(pMesh != NULL);
     FILE *pFile = fopen(pFilename,"rt");
     if(pFile == NULL)
       return false;
     Builder_obj<HalfedgeDS> builder(pFile);
     pMesh->delegate(builder);
     fclose(pFile);
     return true;
Kye Wong
