- To:
- Subject: Re: [cgal-discuss] Questons on Visual Studio project setting : _SECURE_SCL=0
- Date: Fri, 23 Jan 2009 16:05:48 -0200
Hi Joe,
Hi, all
I noticed that all CGAL examples in VC++ have the project setting : _SECURE_SCL=0. I wonder if this is a must for CGAL. In my Visual Studio solution, I have other non-CGAL projects using default _SECURE_SCL=1. In Debug mode, everything runs well. But in Release mode, I got some STL vector errors. Is it possible that the mix of _SECURE_SCL=0 and _SECURE_SCL=1 for different projects in one sultion causes all the trouble?
Yes, it is precisely that.
> Is it safe to set _SECURE_SCL=1 for all CGAL-related projects?
Yes, it is...
Is just that it is then painfully slow. That's why it is turned off by default, but you can have it on sync with the rest of your projects.
HTH
Fernando Cacciola
www.geometryfactory.com
- [cgal-discuss] Questons on Visual Studio project setting : _SECURE_SCL=0, Joe C, 01/23/2009
- Re: [cgal-discuss] Questons on Visual Studio project setting : _SECURE_SCL=0, Fernando Cacciola, 01/23/2009
