- To: <>
- Subject: RE: [cgal-discuss] about running time related to CGAL triangiulation
- Date: Sun, 1 Feb 2009 17:39:28 +0800
- Importance: Normal
Thank you for your reply. I have already optimized the compiler and made sure that it does not have the debugging option selected before. May I ask is it possible that it is related to the memory in my PC? Currently, I am using Window XP and have only less than 10 GB left in my C drive. May I ask if the running may be improved through increasing the memory left? If it may help, how many GB shall I increase? Thanks > Date: Sun, 1 Feb 2009 09:43:45 +0100 > From: > To: > Subject: Re: [cgal-discuss] about running time related to CGAL triangiulation > > Kwok Jasper wrote: > > Excuse me. > > > > I have tried to use the 3D Delaunay Triangulation in CGAL in Visual C++ > > with the following declaration. > > > > typedef CGAL::Exact_predicates_inexact_constructions_kernel K1; > > typedef CGAL::Delaunay_triangulation_3<K1> Triangulation; > > Also, use t.insert(begin(),end()). It uses spatial sorting, which makes > the construction much faster. See the manual. > > > After I have set the compiler optimization in Visual C++, > > when I insert 362272 points into the triangulation, it takes more than > > 20 minutes > > and after the insertion, when I use the iterator such as the > > Finite_facets_iterator, it also takes a lot of time.< br> > > > May I ask if the running time is normal? > > no, it is not normal > > > Or in fact it should be faster in the normal case? > > It should be much faster (a few seconds, depending on your computer) > Be careful to compile your code with the appropriate options (optimized > and without debugging options). > > > Thank you very much for your attention > > > > ------------------------------------------------------------------------ > > ?? Windows Live⢠Photos ??????? ????????? > > <http://www.microsoft.com/windows/windowslive/events.aspx> > > -- > You are currently subscribed to cgal-discuss. > To unsubscribe or access the archives, go to > https://lists-sop.inria.fr/wws/info/cgal-discuss ??MSN Buddy??????d? ??MSN Buddy???! |
- Re: [cgal-discuss] about running time related to CGAL triangiulation, Monique Teillaud, 02/01/2009
- RE: [cgal-discuss] about running time related to CGAL triangiulation, Kwok Jasper, 02/01/2009
- Re: [cgal-discuss] about running time related to CGAL triangiulation, Andreas Fabri, 02/01/2009
