- To: <>
- Subject: RE: [cgal-discuss] about running time related to CGAL triangiulation
- Date: Sun, 1 Feb 2009 19:16:26 +0800
- Importance: Normal
Thnak you for your reply. I am using the data points in the following link http://www.cse.ust.hk/~jamesjjx/bunny_final.pts I have tried to insert all the points at the same time using the iterator. The insertion process takes about 1 minute. As you mentioned earlier that it should takes a few seconds depending on the computer used, may I ask if 60 seconds is still reasonable? Or it should still a bit faster? Thank you very much > Date: Sun, 1 Feb 2009 11:07:02 +0100 > From: > To: > Subject: Re: [cgal-discuss] about running time related to CGAL triangiulation > > Kwok Jasper wrote: > > Thank you for your reply. > > > > I have already optimized the compiler and made sure that it does not > > have the debugging option selected before. > > May I ask is it possible that it is related to the memory in my PC? > > > > Currently, I am using Window XP and have only less than 10 GB left in my > > C drive. > > May I ask if the running may be improved through increasing the memory left? > > If it may help, how many GB shall I increase? > > Hi Jasper, > > This has nothing to do with the drive size, only with the RAM, > but even this should not pose any problem for 362272 points. > > As Monique pointed out, you should either insert all points at > the same time. If you must insert them one after the other, > you should use the Triangulation_hierarchy_2. There is an > example in CGAL-3.4/examples/Triangulation_2 illustrating it. > > Another thing is the point set itself. If it happens to be a > grid the algorithm may be slow. We work on this. > > Finally, can you put the data set on a server so that we can > try to reproduce the timings. > > best regards, > > andreas > > > > > Thanks > > > > > > > > > Date: Sun, 1 Feb 2009 09:43:45 +0100 > > > From: > > > To: > > > Subject: Re: [cgal-discuss] about running time related to CGAL > > triangiulation > > > > > > Kwok Jasper wrote: > > > > Excuse me. > > > > > > > > I have tried to use the 3D Delaunay Triangulation in CGAL in Visual > > C++ > > > > with the following declaration. > > > > > > > > typedef CGAL::Exact_predicates_inexact_constructions_kernel K1; > > > > typedef CGAL::Delaunay_triangulation_3<K1> Triangulation; > > > > > > Also, use t.insert(begin(),end()). It uses spatial sorting, which makes > > > the construction much faster. See the manual. > > > > > > > After I have set the compiler optimization in Visual C++, > > > > when I insert 362272 points into the triangulation, it takes more than > > > > 20 minutes > > > > and after the insertion, when I use the iterator such as the > > > > Finite_facets_iterator, it also takes a lot of time.< br> > > > > > > > May I ask if the running time is normal? > > > > > > no, it is not normal > > > > > > > Or in fact it should be faster in the normal case? > > > > > > It should be much faster (a few seconds, depending on your computer) > > > Be careful to compile your code with the appropriate options (optimized > > > and without debugging options). > > > > > > > Thank you very much for your attention > > > > > > > > > > ------------------------------------------------------------------------ > > > > ?? Windows Live™ Photos ??????? ????????? > > > > <http://www.microsoft.com/windows/windowslive/events.aspx> > > > > > > -- > > > You are currently subscribed to cgal-discuss. > > > To unsubscribe or access the archives, go to > > > https://lists-sop.inria.fr/wws/info/cgal-discuss > > > > ------------------------------------------------------------------------ > > ??MSN Buddy??????d? ??MSN Buddy???! <http://buddy.hk.msn.com/> > > -- > You are currently subscribed to cgal-discuss. > To unsubscribe or access the archives, go to > https://lists-sop.inria.fr/wws/info/cgal-discuss 利用 Windows Live™ Photos 輕?分享相片。 簡易上載及分享照片 |
- Re: [cgal-discuss] about running time related to CGAL triangiulation, Monique Teillaud, 02/01/2009
- RE: [cgal-discuss] about running time related to CGAL triangiulation, Kwok Jasper, 02/01/2009
- Re: [cgal-discuss] about running time related to CGAL triangiulation, Andreas Fabri, 02/01/2009
