- To: <>
- Subject: [cgal-discuss] Delaunay triangulation
- Date: Sun, 1 Feb 2009 22:49:31 +0530
This is my first post.
Does Delaunay triangulation has any limitation? Will it not triangulate closed mesh such as cube ?
Regards
Rajesh.R
This message and any attachments is intended for the sole use of the intended recipient. It may contain confidential information. Any unauthorized use, dissemination or modification is strictly prohibited. If you are not the intended recipient, please notify the sender immediately then delete it from all your systems, and do not copy, use or print. Internet communications are not secure and it is the responsibility of the recipient to make sure that it is virus/malicious code exempt.
The company/sender cannot be responsible for any unauthorized alterations or modifications made to the contents. If you require any form of confirmation of the contents, please contact the company/sender. The company/sender is not liable for any errors or omissions in the content of this message.
- [cgal-discuss] Delaunay triangulation, Rajesh R., 02/01/2009
- Re: [cgal-discuss] Delaunay triangulation, Mariette Yvinec, 02/02/2009
