- To:
- Subject: Re: [cgal-discuss] Delaunay triangulation
- Date: Mon, 02 Feb 2009 09:11:54 +0100
CGAL Delaunay triangulation package computes the Delaunay triangulation
of
a set of points. Computing a triangulation of the domain bounded by a
close surface mesh is another problem, a 3D meshing problem which is
currently
not handle in CGAL.
Rajesh R. wrote:
This is my first post.
Does Delaunay triangulation has any limitation? Will it
not triangulate closed mesh such as cube ?
Regards
Rajesh.R
***** Confidentiality Statement/Disclaimer *****
This message and any attachments is intended for the sole use of the
intended recipient. It may contain confidential information. Any
unauthorized use, dissemination or modification is strictly prohibited.
If you are not the intended recipient, please notify the sender
immediately then delete it from all your systems, and do not copy, use
or print. Internet communications are not secure and it is the
responsibility of the recipient to make sure that it is virus/malicious
code exempt.
The company/sender cannot be responsible for any unauthorized
alterations or modifications made to the contents. If you require any
form of confirmation of the contents, please contact the
company/sender. The company/sender is not liable for any errors or
omissions in the content of this message.
Mariette Yvinec
Geometrica project team
INRIA Sophia-Antipolis
