cgal-discuss - Re: [cgal-discuss] A point not on convex hull
  • To:
  • Subject: Re: [cgal-discuss] A point not on convex hull
  • Date: Wed, 4 Feb 2009 12:00:10 +0100
On Wednesday 04 February 2009 11:38:11 am
wrote:
> Hi All,
> I need to find a particular point from a sample of points of which I made
> convex hull, is on the convex hull or not. I am not finding any particular
> function for it in manual.
> Please give right direction, how to do it. I created ch_object of n points,
> now I don't know which points were involved in making the hull and which
> were excluded.
> Thanks
> Avanindra
Hello,
From the manual page
http://www.cgal.org/Manual/3.4/doc_html/cgal_manual/Convex_hull_2/Chapter_main.html#Section_11.3
You can find one example of how to construct the convex hull of a set of
points. Instead of using the standard input and output like in the example,
you can use lists or another container.
Indeed, following the link behind CGAL::ch_graham_andrew, we can see that the
third parameter of CGAL::ch_graham_andrew is an OutputIterator which gives
you the list of points on the convex hull. A simple equality test then solves
your problem.
Another solution is to use the triangulation_2 and the vertices incident to
the infinite vertex.
Sebastien.
