- To: <>
- Subject: RE: [cgal-discuss] Random Polygon Generator
- Date: Wed, 4 Feb 2009 13:18:18 +0200
Yes, there are many methods (for instance, making a voronoi diagram, and
connect every site to two neighbors, and keeping consistent orientation). I
just wanted to know if there is a ready tool for this.
Amir.
-----Original Message-----
[mailto:]
Sent: Wednesday, February 04, 2009 12:35 PM
To:
Subject: Re: [cgal-discuss] Random Polygon Generator
> Is there any way to produce a random simple polygon (confined in a
> given bounding box) w/holes, with a given complexity n?
depends on what you mean by random simple polygon. :-)
You can, for instance, pick the vertices according to your favorite
distribution and connect them,
1) along their upper convex hull and the rest in lexicographic order;
2) choosing a random permutation and successively flipping edge
crossings;
3) by an (approximate) Minimum TSP tour (e.g., starting from an EMST
and then remove crossings);
4) similar as in the SLR/Graham scan convex hull algorithm, except
that you don't enforce local convexity but only that no point
appears on both chains;
5) ... (probably many other options, depending on what you want)
hth,
Michael
- [cgal-discuss] Random Polygon Generator, Amir Vaxman, 02/04/2009
- Re: [cgal-discuss] Random Polygon Generator, Michael Hoffmann, 02/04/2009
- RE: [cgal-discuss] Random Polygon Generator, Amir Vaxman, 02/04/2009
