cgal-discuss - Re: [cgal-discuss] [HELP] about some advice related to the usage
  • To:
  • Subject: Re: [cgal-discuss] [HELP] about some advice related to the usage
  • Date: Wed, 04 Feb 2009 18:13:26 +0100
Kwok Jasper wrote:
In the class Vertex_base_for_ssr, it has the member vector<Vertex_handle> neighbor_vertex_handle
I have first insert points into a Triangulation, then
for eac h vertex in the triangulation, I set its neighbor_vertex_handle to contain the vertex handle of the its neighbor points
Is there a specific reason why you want to store the neighbors in the vertex?
The triangulation already stores the information, it seems redundant to me to store it twice, unless you have a strong reason to do so.
(also, how are you going to update this information each time it changes when you insert new points...?)
You can easily access the information on adjacent vertices stored by the triangulation and traverse the neighbors of a vertex:
just use t.incident_vertices() that gives you an outputiterator (see reference manual of Triangulation_3)
