cgal-discuss - RE: [cgal-discuss] [HELP] about some advice related to the usage
  • To: <>
  • Subject: RE: [cgal-discuss] [HELP] about some advice related to the usage
  • Date: Thu, 5 Feb 2009 19:36:16 +0800
  • Importance: Normal
Thanks
Actually, the reason that I want to use vector<Vertex_handle> neighbor_vertex_handle
is that for each of the vertex, I want to record its k nearest neighbor (particularly, I want to record 55 nearest neighbor of a point)
In the CGAL manual , I found a function that return the nearest neighbor of a vertex but I cannot find the function that return k nearest neighbor.
Therefore, what I am trying now is to use the following for the k nearest neighbor search
typedef Rep_class::Point_3 Point;
typedef CGAL::Search_traits_3<Rep_class> Traits;
typedef CGAL::Orthogonal_k_neighbor_search<Traits> Neighbor_search;
typedef Neighbor_search::Tree Tree;
    Tree tree_for_search;
    vector<Point_3> neighbor;
    vector<Point_3>::iterator n_itr;
    Finite_vertices_iterator initial = Dt.finite_vertices_begin();
    Finite_vertices_iterator final = Dt.finite_vertices_end();
    Finite_vertices_iterator curr;
    Point_3 * temp;
    double tempX;
    double tempY;
    double tempZ;
   for(curr = initial; curr != final; ++curr)
       tempX = (curr -> point()).x();
       tempY = (curr -> point()).y();
       tempZ = (curr -> point()).z();
       temp = new Point_3(tempX, tempY, tempZ);
       tree_for_search.insert(*temp);
       delete temp;
       temp = NULL;
   Neighbor_search * search;
   Point_3 * query;
   Neighbor_search::iterator itr;
       cout << ++i << "searching neighbor" << endl;
       query = new Point_3(tempX, tempY, tempZ);
       search = new Neighbor_search(tree_for_search, *query, num_of_neighbor);
       itr = search -> begin();
       ++itr;
       int num=0;
       for (; itr != search -> end(); ++itr)
          ++num;
          if (num == 4)
             curr -> fifth_nearest_dist = sqrt(itr -> second);
          neighbor.push_back(itr -> first);
after that, I have a vector<Point_3> containing the coordiante of all the neighbors.
Then, I get the vertex handle of the point in the triangulation having that those coordiante (I have implement a data structure to achieve this task  )
After that, I push those vertex_handle of the neighbor into the vector<Vertex_handle>  of the vertex currently being processed.
May I ask if the above approach has used CGAL improperly that I get the exception that I have mentioned in the previous email ?
Thank you very much.
> Date: Wed, 4 Feb 2009 18:13:26 +0100
> From:
> To:
> Subject: Re: [cgal-discuss] [HELP] about some advice related to the usage
> Kwok Jasper wrote:
> > In the class Vertex_base_for_ssr, it has the member
> > I have first insert points into a Triangulation, then
> > for eac h vertex in the triangulation, I set its neighbor_vertex_handle
> > to contain the vertex handle of the its neighbor points
> Is there a specific reason why you want to store the neighbors in the
> vertex?
> The triangulation already stores the information, it seems redundant to
> me to store it twice, unless you have a strong reason to do so.
> (also, how are you going to update this information each time it changes
> when you insert new points...?)
> You can easily access the information on adjacent vertices stored by the
> triangulation and traverse the neighbors of a vertex:
> just use t.incident_vertices() that gives you an outputiterator (see
> reference manual of Triangulation_3)
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
內在氣質才是致勝之道-您是哪一 最原始的溝通是用心的交流。
