- To:
- Cc:
- Subject: Re: [cgal-discuss] Newbie for CGAL
- Date: Tue, 17 Feb 2009 09:09:26 -0800
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :cc:content-type; b=NFYrD8DfrQo+6LKcG0rr/meDOcFMW9/4p1pa485ehvjCVCuKbVaWNEc7qKXODxwjiq y7BSfXCM179YgU50Y/D0KsZEcCjc7hzuG95Pm+6d3w/7Nj1caY+2ZyyLaHML1Fb3HiUw 9ttoLXkfhoOwRpOxOfLTw3GGmLLAfpflXYs2A=
Hi, Mariette,
Thanks for your prompt reply.
Right now I am gonna use CGAL. The configuration is below:
1. The OS is WinXP.
2. The develop environment is VS 2005
3. CGAL: v 3.4.
Then are there any other pre-requirement needed? (PS: Is there any manual for Window vs2005 developer?)
Thanks,
Jun
2009/2/17 Mariette Yvinec <>
Right know CGAL includes a surface mesh generation package
that handles only surfaces defined through an implicit
function or a grey level in a 3D image ...
Next release (scheduled in september 2009) will probably offer
remeshing of polyhedral surfaces
and hopefully a 3D mesh generation package.
Jun WANG wrote:Hi,
Thanks for your reply.
Since there is no API for 3D model, what kind of file format the CGAL can handle ??? Thanks,
Jun
No, there is currently no API to mesh CAD models in IGES or STEPS format.
Jun WANG wrote:
Dear all,
Right now I have downloaded the lastest CGAL(v 3.4). But I have some questions since I have not ever used it before:
1. Can I use it in VC 6.0 and Window XP OS ?
2. If so, how can I configure that? Otherwise, what kind of platform should I use ?
3. My goal is to triangularize the 3D CAD model formatted with IGES or STEP. Have CGAL provided the related API to realize that ???
Yes, see the chapter 46 "Estimation of Local Differential Properties"
4. In addition, I also intent to calculate the curvature and normal of vertex in triangle mesh after triangulation. Is that available in CGAL ???
of CGAL manual.--
Any response will be greatly appreciated. Thanks a lot.
BRs,
Jun
Mariette Yvinec
Geometrica project team
INRIA Sophia-Antipolis
-- Mariette Yvinec Geometrica project team INRIA Sophia-Antipolis
- [cgal-discuss] Newbie for CGAL, Jun WANG, 02/16/2009
- Re: [cgal-discuss] Newbie for CGAL, Laurent Rineau (GeometryFactory), 02/16/2009
- Re: [cgal-discuss] Newbie for CGAL, Mariette Yvinec, 02/17/2009
- Re: [cgal-discuss] Newbie for CGAL, Jun WANG, 02/17/2009
- Re: [cgal-discuss] Newbie for CGAL, Ashwin N, 02/18/2009
