cgal-discuss - Re: [cgal-discuss] segmentation fault from Nef_polyhedron_2 boolean
  • To:
  • Cc: Liang Tao <>, Michael Simbirsky <>
  • Subject: Re: [cgal-discuss] segmentation fault from Nef_polyhedron_2 boolean
  • Date: Wed, 18 Feb 2009 09:08:01 -0800
Hi Andreas,
The kernel which you suggested improves the speed more than 2 times.
Thanks for your help and explanation.
Thanks,
Hyungon Kim
Andreas Fabri wrote:
Hi Hyungon,
It doesn't surprise me that just Gmpq is too slow.
Can you give the following a try:
#include <CGAL/Lazy_exact_nt.h>
typedef CGAL::Simple_cartesian<CGAL::Lazy_exact_nt<CGAL::Gmpq> > Kernel;
It's a numbertype that encloses the floating point coordinates in floating
point intervals, does interval arithmetic, and only falls back to the
expensive computation using Gmpq if things fail with floating point arithmetic.
andreas
Hyungon Kim wrote:
Hi Andreas,
I tested Nef_polyhedron 2D boolean operation for four kernels with two simple polygons;
two of them are inexact (long and double) and others exact (MP_Float and Gmpq).
The cases of MP_float and Gmpq outputs correct polygons, but long and double crashed.
The problem of MP_float and Gmpq is too slow to use them and make product.
More than 16 times slow compared to the package using now.
As you can see the attached picture, simple polygons were tested and then just crashed.
Is there a way to avoid crash with inexact even when the exact output is not necessary?
Thanks,
Hyungon Kim
Hyungon Kim wrote:
Hi Andreas,
I think it is not exact construction problem and also not related to regularization.
create_face_objects in Nef2/PM_overlayer.h crashed with example polygons.
And even using exact construct also crashed at same place.
Thanks,
Hyungon Kim
Hello,
Both, Nef and the Regularizded Boolean operations need exact constructions.
In order to decide which of the two packages is the better choice depends
on your requirements. Nef does not regularize, that is it can represent
isolated points, unbounded faces, open faces, antennas sticking out, etc.
andreas
wrote:
Hi,
Nef_polyhedron_2 boolean operation crushed for some polygons. However, it is
fine when trying General_polygon_set with same polygons. Should I use
General_polygon_set instead of Nef_polyhedron_2 even for simple rectilinear
polygon?
Thanks,
Hyungon Kim
#include <iostream>
#include <list>
using namespace std;
#include <CGAL/basic.h>
#include <CGAL/Gmpq.h>
#include <CGAL/Simple_cartesian.h>
#include <CGAL/connect_holes.h>
#include <CGAL/Bounded_kernel.h>
#include <CGAL/Nef_polyhedron_2.h>
#include <CGAL/Polygon_2.h>
#include <CGAL/Polygon_with_holes_2.h>
#include <CGAL/Boolean_set_operations_2.h>
typedef CGAL::Simple_cartesian<double> cgalKernel;
typedef CGAL::Bounded_kernel<cgalKernel> cgalExtKernel;
typedef CGAL::Nef_polyhedron_2<cgalExtKernel> cgalNefPolyhedron;
typedef cgalNefPolyhedron::Point cgalPoint2;
typedef CGAL::Polygon_2<cgalKernel> cgalPolygon2;
typedef CGAL::Polygon_with_holes_2<cgalKernel> cgalPolygonWithHoles2;
typedef CGAL::Exact_predicates_inexact_constructions_kernel cgalExtInextKernel;
typedef cgalExtInextKernel::Point_2 cgalExtPoint2;
typedef CGAL::Polygon_2<cgalExtInextKernel> cgalExtPolygon2;
typedef CGAL::Polygon_with_holes_2<cgalExtInextKernel> cgalExtPolygonWithHoles2;
main()
vector<cgalPoint2> P1;
P1.push_back(cgalPoint2(-48690,20167));
P1.push_back(cgalPoint2(-48690,1960));
P1.push_back(cgalPoint2(-42690,-4038));
P1.push_back(cgalPoint2(-42690,-17679));
P1.push_back(cgalPoint2(-17677,-42690));
P1.push_back(cgalPoint2(17679,-42690));
P1.push_back(cgalPoint2(42690,-17677));
P1.push_back(cgalPoint2(42690,-4460));
P1.push_back(cgalPoint2(37690,-4460));
P1.push_back(cgalPoint2(37690,-15613));
P1.push_back(cgalPoint2(15611,-37690));
P1.push_back(cgalPoint2(-15613,-37690));
P1.push_back(cgalPoint2(-37690,-15611));
P1.push_back(cgalPoint2(-37690,-1962));
P1.push_back(cgalPoint2(-43690,4040));
P1.push_back(cgalPoint2(-43690,18103));
P1.push_back(cgalPoint2(-18101,43690));
P1.push_back(cgalPoint2(18103,43690));
P1.push_back(cgalPoint2(43690,18101));
P1.push_back(cgalPoint2(43690,7500));
P1.push_back(cgalPoint2(78690,7500));
P1.push_back(cgalPoint2(78690,12500));
P1.push_back(cgalPoint2(48690,12500));
P1.push_back(cgalPoint2(48690,20169));
P1.push_back(cgalPoint2(20167,48690));
P1.push_back(cgalPoint2(-20169,48690));
vector<cgalPoint2> P2;
P2.push_back(cgalPoint2(-48690,-1960));
P2.push_back(cgalPoint2(-48690,-9460));
P2.push_back(cgalPoint2(-43690,-9460));
P2.push_back(cgalPoint2(-43690,-4040));
P2.push_back(cgalPoint2(-37690,1962));
P2.push_back(cgalPoint2(-37690,9460));
P2.push_back(cgalPoint2(-42690,9460));
P2.push_back(cgalPoint2(-42690,4038));
cgalNefPolyhedron N1(P1.begin(), P1.end(),
cgalNefPolyhedron::EXCLUDED);
cgalNefPolyhedron N2(P2.begin(), P2.end(),
cgalNefPolyhedron N3 = N1+N2;
cgalPolygon2 POLY1(P1.begin(), P1.end());
cgalPolygon2 POLY2(P2.begin(), P2.end());
cgalPolygonWithHoles2 unionR;
CGAL::join(POLY1, POLY2, unionR);
