cgal-discuss - Re: [cgal-discuss] segmentation fault from Nef_polyhedron_2 boolean
  • To:
  • Subject: Re: [cgal-discuss] segmentation fault from Nef_polyhedron_2 boolean
  • Date: Thu, 12 Feb 2009 07:36:57 +0100
Hello,
Both, Nef and the Regularizded Boolean operations need exact constructions.
In order to decide which of the two packages is the better choice depends
on your requirements. Nef does not regularize, that is it can represent
isolated points, unbounded faces, open faces, antennas sticking out, etc.
andreas
wrote:
Hi,
Nef_polyhedron_2 boolean operation crushed for some polygons. However, it is
fine when trying General_polygon_set with same polygons. Should I use
General_polygon_set instead of Nef_polyhedron_2 even for simple rectilinear
polygon?
Thanks,
Hyungon Kim
#include <iostream>
#include <list>
using namespace std;
#include <CGAL/basic.h>
#include <CGAL/Gmpq.h>
#include <CGAL/Simple_cartesian.h>
#include <CGAL/connect_holes.h>
#include <CGAL/Bounded_kernel.h>
#include <CGAL/Nef_polyhedron_2.h>
#include <CGAL/Polygon_2.h>
#include <CGAL/Polygon_with_holes_2.h>
#include <CGAL/Boolean_set_operations_2.h>
typedef CGAL::Simple_cartesian<double> cgalKernel;
typedef CGAL::Bounded_kernel<cgalKernel> cgalExtKernel;
typedef CGAL::Nef_polyhedron_2<cgalExtKernel> cgalNefPolyhedron;
typedef cgalNefPolyhedron::Point cgalPoint2;
typedef CGAL::Polygon_2<cgalKernel> cgalPolygon2;
typedef CGAL::Polygon_with_holes_2<cgalKernel>
cgalPolygonWithHoles2;
typedef CGAL::Exact_predicates_inexact_constructions_kernel cgalExtInextKernel;
typedef cgalExtInextKernel::Point_2 cgalExtPoint2;
typedef CGAL::Polygon_2<cgalExtInextKernel> cgalExtPolygon2;
typedef CGAL::Polygon_with_holes_2<cgalExtInextKernel> cgalExtPolygonWithHoles2;
main()
vector<cgalPoint2> P1;
P1.push_back(cgalPoint2(-48690,20167));
P1.push_back(cgalPoint2(-48690,1960));
P1.push_back(cgalPoint2(-42690,-4038));
P1.push_back(cgalPoint2(-42690,-17679));
P1.push_back(cgalPoint2(-17677,-42690));
P1.push_back(cgalPoint2(17679,-42690));
P1.push_back(cgalPoint2(42690,-17677));
P1.push_back(cgalPoint2(42690,-4460));
P1.push_back(cgalPoint2(37690,-4460));
P1.push_back(cgalPoint2(37690,-15613));
P1.push_back(cgalPoint2(15611,-37690));
P1.push_back(cgalPoint2(-15613,-37690));
P1.push_back(cgalPoint2(-37690,-15611));
P1.push_back(cgalPoint2(-37690,-1962));
P1.push_back(cgalPoint2(-43690,4040));
P1.push_back(cgalPoint2(-43690,18103));
P1.push_back(cgalPoint2(-18101,43690));
P1.push_back(cgalPoint2(18103,43690));
P1.push_back(cgalPoint2(43690,18101));
P1.push_back(cgalPoint2(43690,7500));
P1.push_back(cgalPoint2(78690,7500));
P1.push_back(cgalPoint2(78690,12500));
P1.push_back(cgalPoint2(48690,12500));
P1.push_back(cgalPoint2(48690,20169));
P1.push_back(cgalPoint2(20167,48690));
P1.push_back(cgalPoint2(-20169,48690));
vector<cgalPoint2> P2;
P2.push_back(cgalPoint2(-48690,-1960));
P2.push_back(cgalPoint2(-48690,-9460));
P2.push_back(cgalPoint2(-43690,-9460));
P2.push_back(cgalPoint2(-43690,-4040));
P2.push_back(cgalPoint2(-37690,1962));
P2.push_back(cgalPoint2(-37690,9460));
P2.push_back(cgalPoint2(-42690,9460));
P2.push_back(cgalPoint2(-42690,4038));
cgalNefPolyhedron N1(P1.begin(), P1.end(),
cgalNefPolyhedron::EXCLUDED);
cgalNefPolyhedron N2(P2.begin(), P2.end(),
cgalNefPolyhedron N3 = N1+N2;
cgalPolygon2 POLY1(P1.begin(), P1.end());
cgalPolygon2 POLY2(P2.begin(), P2.end());
cgalPolygonWithHoles2 unionR;
CGAL::join(POLY1, POLY2, unionR);
