- To:
- Subject: [cgal-discuss] Access to original points in 2D triangulation
- Date: Sun, 22 Feb 2009 12:46:28 +0800
Hi,
I'm new to CGAL and now I'm using Triangulation_2 to generate a
triangulation.
I wonder that if there is an efficient way to access to the points
before I insert them into triangulation. For example, if I write
Triangulation_2 t;
std::vector<Point_2> p;
t.insert(p.begin(), p.end());
How can I get the vertex in t that holds p.front()? I know t.locate will
do that, but I think it is an inefficient way if I want to locate all
points in p.
Thank you for your help.
- [cgal-discuss] Access to original points in 2D triangulation, Cai Zhenning, 02/22/2009
- Re: [cgal-discuss] Access to original points in 2D triangulation, Laurent Rineau (GeometryFactory), 02/22/2009
