- To:
- Subject: Re: [cgal-discuss] Access to original points in 2D triangulation
- Date: Sun, 22 Feb 2009 19:23:31 +0100
On Sunday 22 February 2009 05:46:28 Cai Zhenning wrote:
> Hi,
> I'm new to CGAL and now I'm using Triangulation_2 to generate a
> triangulation.
> I wonder that if there is an efficient way to access to the points
> before I insert them into triangulation. For example, if I write
> Triangulation_2 t;
> std::vector<Point_2> p;
> t.insert(p.begin(), p.end());
> How can I get the vertex in t that holds p.front()? I know t.locate will
> do that, but I think it is an inefficient way if I want to locate all
> points in p.
You need to insert the points one by one. Something like that:
std::vector<Triangulation_2::Vertex_handle> handles;
Triangulation_2::Face_handle f;
typedef std::vector<Point_2>::const_iterator iterator;
for(iterator it = p.begin(); it != p.end(); ++it)
Triangulation_2::Vertex_handle v = t.insert(*it, f);
handles.push_back(v);
f = v->face();
The variable f is a possible optimization, if your points are sorted. You can
even sort them *before* the insertion, using the spatial sort:
#include <CGAL/spatial_sort.h>
CGAL::spatial_sort(p.begin, p.end());
but not that this will modify your vector of points.
Laurent Rineau, PhD
Engineer at GeometryFactory
http://www.geometryfactory.com/
- [cgal-discuss] Access to original points in 2D triangulation, Cai Zhenning, 02/22/2009
- Re: [cgal-discuss] Access to original points in 2D triangulation, Laurent Rineau (GeometryFactory), 02/22/2009
