cgal-discuss - Re: [cgal-discuss] constructor of Nef_polyhedron_2 with polygons
  • To:
  • Subject: Re: [cgal-discuss] constructor of Nef_polyhedron_2 with polygons
  • Date: Tue, 24 Feb 2009 22:15:58 +0100
On Tuesday 24 February 2009 20:41:13
wrote:
> Hi,
> I saw a constructor of Nef_polyhedron with polygons from on-line manual
> like Nef_polyhedron_2<T> N ( Forward_iterator it, Forward_iterator end,
> Polygons_tag);
> However, not in Release 3.3.1 25 August 2007 User and Reference manual.
> Anyway, I failed to use this constructor with 3.3.1. Should I use CGAL 3.4
> instead of 3.3.1 to use the constructor with polygons.
Compare the two following documentation pages:
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Nef_3_ref/Class_Nef_polyhedron_3.html
http://www.cgal.org/Manual/3.4/doc_html/cgal_manual/Nef_3_ref/Class_Nef_polyhedron_3.html
The first one is from CGAL-3.3.x, and the second one is from CGAL-3.4. Then
you get your answer: your constructor is not documented in CGAL-3.3. I do not
really know the Nef_3 package, but I assume it means that this constructor is
not availlable in CGAL-3.3.1.
Laurent Rineau, PhD
Engineer at GeometryFactory
http://www.geometryfactory.com/
