cgal-discuss - Re: [cgal-discuss] constructor of Nef_polyhedron_2 with polygons
  • To:
  • Subject: Re: [cgal-discuss] constructor of Nef_polyhedron_2 with polygons
  • Date: Wed, 25 Feb 2009 09:09:52 -0800
Laurent Rineau (GeometryFactory) wrote:
On Tuesday 24 February 2009 20:41:13
wrote:
Hi,
I saw a constructor of Nef_polyhedron with polygons from on-line manual
like Nef_polyhedron_2<T> N ( Forward_iterator it, Forward_iterator end,
Polygons_tag);
However, not in Release 3.3.1 25 August 2007 User and Reference manual.
Anyway, I failed to use this constructor with 3.3.1. Should I use CGAL 3.4
instead of 3.3.1 to use the constructor with polygons.
Compare the two following documentation pages:
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Nef_3_ref/Class_Nef_polyhedron_3.html
http://www.cgal.org/Manual/3.4/doc_html/cgal_manual/Nef_3_ref/Class_Nef_polyhedron_3.html
The first one is from CGAL-3.3.x, and the second one is from CGAL-3.4. Then you get your answer: your constructor is not documented in CGAL-3.3. I do not really know the Nef_3 package, but I assume it means that this constructor is not availlable in CGAL-3.3.1.
Hi Laurent,
Thanks for your reply.
Best Regards,
Hyungon Kim
