- To:
- Subject: [cgal-discuss] An Example of Nef Polyhedra doesn't work correctly
- Date: Sat, 28 Feb 2009 17:35:19 +0200
Hello,
I tried to operate the example "point_set_operations" of Nef3 polyhedra. I am
using a VC8(2005) with CGAL 3.4. When I try to run the example verbatim, with
the kernel definition as:
"typedef CGAL::extended_homogeneous<CGAL::gmpz> Kernel", in debug mode, it
runs
VERY slowly, up to the point where I couldn't keep on and stopped the
debugging
manually. If I use the workaround offered in the documentation:
"struct Kernel : public CGAL::Extended_homogeneous<NT> {};"
the constructors of N1-6 assert that there is no proper construction during
runtime.
I add the aforementioned example file.
Thanks,
Amir.
#include <CGAL/Gmpz.h>
#include <CGAL/Extended_homogeneous.h>
#include <CGAL/Nef_polyhedron_3.h>
typedef CGAL::Extended_homogeneous<CGAL::Gmpz> Kernel;
typedef CGAL::Nef_polyhedron_3<Kernel> Nef_polyhedron;
typedef Kernel::Plane_3 Plane_3;
int main() {
Nef_polyhedron N1(Plane_3( 1, 0, 0,-1));
Nef_polyhedron N2(Plane_3(-1, 0, 0,-1));
Nef_polyhedron N3(Plane_3( 0, 1, 0,-1));
Nef_polyhedron N4(Plane_3( 0,-1, 0,-1));
Nef_polyhedron N5(Plane_3( 0, 0, 1,-1));
Nef_polyhedron N6(Plane_3( 0, 0,-1,-1));
Nef_polyhedron I1(!N1 + !N2); // open slice in yz-plane
Nef_polyhedron I2(N3 - !N4); // closed slice in xz-plane
Nef_polyhedron I3(N5 ^ N6); // open slice in yz-plane
Nef_polyhedron Cube1(I2 * !I1);
Cube1 *= !I3;
Nef_polyhedron Cube2 = N1 * N2 * N3 * N4 * N5 * N6;
CGAL_assertion(Cube1 == Cube2); // both are closed cube
CGAL_assertion(Cube1 == Cube1.closure());
CGAL_assertion(Cube1 == Cube1.regularization());
CGAL_assertion((N1 - N1.boundary()) == N1.interior());
CGAL_assertion(I1.closure() == I1.complement().interior().complement());
CGAL_assertion(I1.regularization() == I1.interior().closure());
return 0;
- [cgal-discuss] An Example of Nef Polyhedra doesn't work correctly, avaxman, 02/28/2009
