- To:
- Subject: Re: [cgal-discuss] Arrangement of patches\planes using Nef Polyhedra
- Date: Sat, 28 Feb 2009 22:15:28 +0100
Amir Vaxman wrote:
Hello,
Is it possible to create an arrangement of planar patches in 3-space using Nef Polyhedra? As a special case, the arrangement of full planes.
Amir.
Hi Amir,
As full planes are valid Nef polyhedra, you can apply the join operation
on them in order to obtain their arrangement.
Concerning the planar patches the main difficulty will be to generate them.
If they are given as a polygon with floating point coordinates on a plane
chances are high that the precondition fails that the points must be coplanar.
best regards,
andreas
- [cgal-discuss] Arrangement of patches\planes using Nef Polyhedra, Amir Vaxman, 02/25/2009
- Re: [cgal-discuss] Arrangement of patches\planes using Nef Polyhedra, Andreas Fabri, 02/28/2009
- Re: [cgal-discuss] Arrangement of patches\planes using Nef Polyhedra, avaxman, 02/28/2009
