cgal-discuss - [cgal-discuss] about accessing end points of dual voronoi edge of a triangle inside a triangulation
  • To: <>
  • Subject: [cgal-discuss] about accessing end points of dual voronoi edge of a triangle inside a triangulation
  • Date: Mon, 2 Mar 2009 14:02:49 +0800
  • Importance: Normal
Excuse me.
I have used the following to find out the dual voronoi edge of a triangle in a triangulation.
CGAL:Object obj = Dt.dual(*temp);                            //where temp is a facet iterator
Segment ve;
if (assign(ve, obj))
       temp_dual_voronoi_edge_of_triangle.start();     //then, I tried to acess the end points of the dual voronoi edge by using these 2 lines of codes
       temp_dual_voronoi_edge_of_triangle.end();
by using the start() and end() function, I can get the end points of the dual voronoi edge as a type of Point
May I ask if I want to get such end points as a type of Vertex_handle of the triangulation instead of type Point, then what may I do ?
I cannot found any function in the CGAL manual which do the above directly in a single step.
Thank you very much
收發郵件以外 - 了解更多Windows Live™卓越功能 收發郵件以外更多功能
