- To:
- Subject: Re: [cgal-discuss] "Vector<T> too long" exception in release mode
- Date: Mon, 09 Mar 2009 11:35:07 +0100
Mohamed,
thanks for your answer and suggestion - it worked pretty well and now I
can do my things without this annoying error :)
Regards,
Tom
Mohamed BENDAOUD schrieb:
> hi Tom Kazimiers,
> I had the same problem with voronoi. i was using this kernels :
> #include "include/CGAL/basic.h"
> #include "include/CGAL/Exact_predicates_inexact_constructions_kernel.h"
> #include "include/CGAL/Delaunay_triangulation_2.h"
> #include "include/CGAL/Voronoi_diagram_2.h"
> #include "include/CGAL/Delaunay_triangulation_adaptation_traits_2.h"
> #include "include/CGAL/Delaunay_triangulation_adaptation_policies_2.h"
> #include "include/CGAL/MP_Float.h"
> // typedefs for defining the adaptor
> typedef
> CGAL::Exact_predicates_inexact_constructions_kernel K;
> typedef
> CGAL::Delaunay_triangulation_2<K> DT;
> typedef
> CGAL::Delaunay_triangulation_adaptation_traits_2<DT> AT;
> typedef
> CGAL::Delaunay_triangulation_caching_degeneracy_removal_policy_2<DT> AP;
> typedef
> CGAL::Voronoi_diagram_2<DT,AT,AP> VD;
> to resolve the problem i changed typedef
> K; by :
> #include "include/CGAL/Simple_cartesian.h"
> typedef CGAL::Simple_cartesian<double> K;
> in my case CGAL::Uncertain_conversion_exception was the main problem.
> i don't know if it can help. good luck.
- Re: [cgal-discuss] about query k nearest neighbor point in Delaunay triangulation, Query Cgal, 03/01/2009
- <Possible follow-up(s)>
- Re: [cgal-discuss] about query k nearest neighbor point in Delaunay triangulation, Laurent Rineau (GeometryFactory), 03/02/2009
- [cgal-discuss] "Vector<T> too long" exception in release mode, Tom Kazimiers, 03/02/2009
- Re: [cgal-discuss] "Vector<T> too long" exception in release mode, Tom Kazimiers, 03/04/2009
- [cgal-discuss] "Vector<T> too long" exception in release mode, Mohamed BENDAOUD, 03/08/2009
- Re: [cgal-discuss] "Vector<T> too long" exception in release mode, Tom Kazimiers, 03/09/2009
