- To:
- Subject: Re: [cgal-discuss] Mesh Cutting
- Date: Tue, 03 Mar 2009 15:42:30 +0100
- Organization: INRIA
hi Chaman, the disks required for the parameterization are...topological disks, ie the input chain of halfedges must bound a disk. If I follow your next email about isotropic remeshing perhaps you are trying to re-implement "Isotropic Remeshing of Surfaces: a Local Parameterization Approach" ? unfortunately I have not put the implementation in CGAL and (I do not have one to send you) you can always check at any point in time during remeshing check that a patch is a disk and in the negative, construct one by region growing while enforcing this property. pierre Pierre Alliez INRIA Sophia Antipolis - Mediterranee Project-team GEOMETRICA http://www-sop.inria.fr/members/Pierre.Alliez/ Tel: +33 4 92 38 76 77 Fax: +33 4 97 15 53 95 Chaman Singh Verma a écrit : Hello, |
- [cgal-discuss] Mesh Cutting, Chaman Singh Verma, 03/03/2009
- Re: [cgal-discuss] Mesh Cutting, Pierre Alliez, 03/03/2009
- Re: [cgal-discuss] Mesh Cutting, Chaman Singh Verma, 03/03/2009
