- To: "cgal-discuss" <>
- Subject: AW: Re: Antwort: [cgal-discuss] install cgal 3.4 devian lenny
- Date: Thu, 5 Mar 2009 19:09:55 +0100
- Importance: Normal
Hi,
Yes I use the Debian package. That means I can not use Leda and Taucs?
The error message below arrives on every demo or example I want to open. The
cmake and make is working.
BlackBerry Enterprise wireless MailSystem
***** powered by Magna Powertrain *****
----- Originalnachricht -----
Von: Joachim Reichel
Gesendet: 05.03.2009 18:55 CET
An:
Betreff: Re: Antwort: [cgal-discuss] install cgal 3.4 devian lenny
Hi,
> only this is interesting for me:
> after make of a special demo or example I want to let it run with the
> executable:
> the following message arises:
> terminate called after throwing an instance of 'CGAL::Assertion_exception'
> what(): CGAL ERROR: assertion violation!
> Expr: -CGAL_IA_MUL(-1.1, 10.1) != CGAL_IA_MUL(1.1, 10.1)
> File: /usr/include/CGAL/Interval_nt.h
> Line: 154
> Explanation: Wrong rounding: did you forget the -frounding-math option if
> you
> use GCC?
it would be helpful if you would tell which demo you tried to execute.
Please attach all the output of the demo compilation process.
Do you now use your self-build CGAL or the Debian packages. Note that
the Debian package have no support for LEDA and TAUCS (since these
packages are not in Debian). If you use your self-build CGAL you should
deinstall the Debian packages (or make sure that you don't mix them,
e.g. the error message above references /usr/include/CGAL/Interval_nt.h).
Please see also http://www.cgal.org/bug_report.html
Joachim
Engineering Center Steyr GmbH & Co KG
Geschaeftsfuehrende Gesellschaft: Engineering Center Steyr GmbH
Geschaeftsfuehrer der geschaeftsfuehrenden Gesellschaft: Dipl. Ing. Franz
Dorfer
Sitz der geschaeftsfuehrenden Gesellschaft: 4300 St. Valentin, Oesterreich
Firmenbuchgericht: St. Poelten / FN 140816h
Sitz der Gesellschaft: 4300 St. Valentin, Steyrer Strasse 32, Oesterreich
Firmenbuchgericht: St. Poelten / FN 222001y
CONFIDENTIALITY NOTE: This message contains information which may be
privileged or confidential, or exempt from disclosure under applicable law.
If the reader of this message is not the intended recipient, or the employee
or agent responsible for delivering the message to the intended recipient,
you are hereby notified that any dissemination, distribution, retention,
archiving, or copying of this communication is strictly prohibited. If you
have received this e-mail in error, please notify us immediately by return
e-mail to the sender of this message.
- AW: Re: Antwort: [cgal-discuss] install cgal 3.4 devian lenny, Martin . Schifko, 03/05/2009
