- To:
- Subject: Re: [cgal-discuss] install cgal 3.4 devian lenny
- Date: Thu, 05 Mar 2009 16:13:12 -0200
Hi martin,
Explanation: Wrong rounding: did you forget the -frounding-math option if youThis happens because the installation is failing to recognize the gcc compiler, thus it is not adding that required flag.
use GCC?
Please post the complete output of running "cmake ." having deleted the file CMakeCache.txt first.
Best
Fernando Cacciola
www.geometryfactory.com
- [cgal-discuss] install cgal 3.4 devian lenny, martin.schifko, 03/05/2009
- Antwort: [cgal-discuss] install cgal 3.4 devian lenny, Martin . Schifko, 03/05/2009
- Re: Antwort: [cgal-discuss] install cgal 3.4 devian lenny, Joachim Reichel, 03/05/2009
- Re: [cgal-discuss] install cgal 3.4 devian lenny, Fernando Cacciola, 03/05/2009
- Re: Re: [cgal-discuss] install cgal 3.4 devian lenny, martin.schifko, 03/06/2009
- Re: [cgal-discuss] install cgal 3.4 devian lenny, Joachim Reichel, 03/06/2009
- Re: [cgal-discuss] install cgal 3.4 devian lenny, Laurent Rineau (GeometryFactory), 03/06/2009
- Antwort: Re: [cgal-discuss] install cgal 3.4 devian lenny, Martin . Schifko, 03/06/2009
