- To: "" <>
- Subject: Re: [cgal-discuss] Dealing with Point_set_2
- Date: Sat, 7 Mar 2009 00:41:01 +0800
Hi,
You can include <climit> or
<limit.h>
Best,
2009-03-07
zengming
发件人: Christoph Weber
发送时间: 2009-03-07 00:15:39
收件人: cgal-liste
抄送:
主题: [cgal-discuss] Dealing with
Point_set_2
Hello,
I tried to compile the examle file
/examples/Point_set_2/range_search.cpp
and I got the following error:
In file included from range_search.cpp:2:
../../include/CGAL/Point_set_2.h: In member function ‘void
CGAL::Point_set_2 <Gt, Tds >::init_dfs()’:
../../include/CGAL/Point_set_2.h:307: error: ‘INT_MAX’ was not declared
in this scope
Maybe, INT_MAX is declared somewhere else? The header, I've included
are:
#include <iostream >
#include <fstream >
#include <cassert >
#include <CGAL/Exact_predicates_inexact_constructions_kernel.h
#include <CGAL/Point_set_2.h >
#include <list >
I hope, somebode can help me.
regards,
Christoph
- [cgal-discuss] Dealing with Point_set_2, Christoph Weber, 03/06/2009
- Re: [cgal-discuss] Dealing with Point_set_2, zengming, 03/06/2009
- Re: [cgal-discuss] Dealing with Point_set_2, Christoph Weber, 03/06/2009
- Re: [cgal-discuss] Dealing with Point_set_2, Laurent Rineau (GeometryFactory), 03/06/2009
