- To:
- Subject: Re: [cgal-discuss] Dealing with Point_set_2
- Date: Fri, 06 Mar 2009 18:09:03 +0100
hm...
there is already a <climits> included in Point_set_2.h, but when I
looked in my climits files (I found 5 !?), MAX_INT was not defined
there. I will define ist by myself, next week. Thanks
reg, Christoph
Am Samstag, den 07.03.2009, 00:41 +0800 schrieb zengming:
> Hi,
> You can include <climit> or <limit.h>
> Best,
> 2009-03-07
> ______________________________________________________________________
> zengming
> 发件人: Christoph Weber
> 发送时间: 2009-03-07 00:15:39
> 收件人: cgal-liste
> 抄送:
> 主题: [cgal-discuss] Dealing with Point_set_2
> Hello,
> I tried to compile the examle file
> /examples/Point_set_2/range_search.cpp
> and I got the following error:
> In file included from range_search.cpp:2:
> ../../include/CGAL/Point_set_2.h: In member function ‘void
> CGAL::Point_set_2 <Gt, Tds >::init_dfs()’:
> ../../include/CGAL/Point_set_2.h:307: error: ‘INT_MAX’ was not declared
> in this scope
> Maybe, INT_MAX is declared somewhere else? The header, I've included
> are:
> #include <iostream >
> #include <fstream >
> #include <cassert >
> #include <CGAL/Exact_predicates_inexact_constructions_kernel.h >
> #include <CGAL/Point_set_2.h >
> #include <list >
> I hope, somebode can help me.
> regards,
> Christoph
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] Dealing with Point_set_2, Christoph Weber, 03/06/2009
- Re: [cgal-discuss] Dealing with Point_set_2, zengming, 03/06/2009
- Re: [cgal-discuss] Dealing with Point_set_2, Christoph Weber, 03/06/2009
- Re: [cgal-discuss] Dealing with Point_set_2, Laurent Rineau (GeometryFactory), 03/06/2009
