cgal-discuss - [cgal-discuss] 3D alpha shapes to Polyhedrons
  • To:
  • Subject: [cgal-discuss] 3D alpha shapes to Polyhedrons
  • Date: Sat, 7 Mar 2009 22:48:01 -0700
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:date:message-id:subject:from:to:content-type :content-transfer-encoding; b=ITxJSFHZ7F9RszktP5Z84yCNVNOsa2u8agHRDuhRnFbVXu9HKp/MSVoqp5DheLuPMU HxkDswcnJdz0St4Xy7ItI6foZjhxQWPLqoE7UieE7nj5qjvY02iDV1dfLzma066fj0hS WgGZD7l6ClLj7GdTAKxn8g4Cu8mrcmCuAZBrs=
Hello, sorry if this topic has been covered already, I tried searching
the archives but they seem to be down at the moment.
I am using alpha shapes to get a shape from a set of points, and then
I convert it to a polyhedron using
CGAL::Polyhedron_incremental_builder_3 to get the boundary facets to
perform further operations.
This works most of the time, but every so often I get the following error :
CGAL::Polyhedron_incremental_builder_3<HDS>::
add_vertex_to_facet(): input error: disconnected facet complexes at vertex
636:
involved facets are: 472 470 471 (closed cycle) and.
terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: check_protocoll == 1
File: ../../CGAL-3.4/include/CGAL/Polyhedron_incremental_builder_3.h
Line: 224
I have tried using different kernels but the error keeps popping up on
the polyhedron builder.
Any help would be greatly appreciated.
Omar
