- To:
- Subject: Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?
- Date: Sat, 7 Mar 2009 22:32:19 -0800 (PST)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=Message-ID:X-YMail-OSG:Received:X-Mailer:References:Date:From:Subject:To:In-Reply-To:MIME-Version:Content-Type; b=hXMp2gL0hSVLCaMuMaUI5doLucRPY1KYzqAqsCFjy2bG6uzn76OEor971iliPBM4U7wM8LdU8CJ6KASgHyMBPhalwpKWwHknXda2UNVyaU/mj5BnpygAcWOHws8ayJNKv5LGQZeONZh0imvC39C1MD9zOSaaSky1R5n0I2zD7rU=;
Hi,
>now I deinstalled CGAL 3.3.1 completely and reinstalled CGAL 3.4 again,
>checked the environment variables, hardcoded absolute directory,
>recompiled and even in the generated example files I get these errors.
I compiled the example without any problem. You have to use "cmake-gui.exe"
instead of "cmake.exe". Do you have the right precompiled libs for gmp (debug version)?
can you build CGAL.sln after you configure it for VS?
Mahmood Naderan
To:
Sent: Saturday, March 7, 2009 4:18:41 PM
Hi,
Do you have any suggestions where to look else?
Regards,
Tom
Tom Kazimiers schrieb:
> Fernando,
> thanks for your reply. I checked everyting by putting in the CGAL
> 3..4-Paths fully, without environment variables - the same result.
> Like I said points the CGALROOT environment variable to the CGAL 3.4
> root directory.
> The output of cmake is the following:
> P:\Program Files (x86)\CGAL-3.4>cmake .
> -- CGAL_MAJOR_VERSION=3
> -- CGAL_MINOR_VERSION=4
> -- CGAL_BUILD_VERSION=
> -- CGAL_SONAME_VERSION=3
> -- CGAL_SOVERSION =3.0.0
> -- CGAL_REFERENCE_CACHE_DIR=
> -- Building static libraries
> CMake Warning (dev) at CMakeLists.txt:88 (include):
> Policy CMP0011 is not set: Included scripts do automatic cmake_policy PUSH
> and POP. Run "cmake --help-policy CMP0011" for policy details. Use the
> cmake_policy command to set the policy and suppress this warning.
> The included script
> P:/Program Files (x86)/CGAL-3.4/cmake/modules/CGAL_Common.cmake
> affects policy settings. CMake is implying the NO_POLICY_SCOPE option for
> compatibility, so the effects are applied to the including context.
> This warning is for project developers. Use -Wno-dev to suppress it.
> -- Targetting Visual Studio 9 2008
> -- Target build enviroment supports auto-linking
> -- Using VC90 compiler.
> -- Generator uses intermediate configuration directory: $(OutDir)
> -- USING CMake version: 2.6.3
> -- System: Windows
> -- Build type: Release
> -- USING CXXFLAGS = ' /DWIN32 /D_WINDOWS /W3 /Zm1000 /EHsc /GR
> -D_CRT_SECURE_NO_DEPRECA
> _SCL_SECURE_NO_WARNINGS /MD /O2 /Ob2 /D NDEBUG -D_SECURE_SCL=0'
> -- USING LDFLAGS = ' '
> -- GMP include: P:/Program Files (x86)/CGAL-3.4/auxiliary/gmp/include
> -- GMP libraries:
> -- GMP definitions:
> -- USING GMP_VERSION = '4.2.4'
> -- MPFR include: P:/Program Files (x86)/CGAL-3.4/auxiliary/gmp/include
> -- MPFR libraries:
> -- MPFR definitions:
> -- USING MPFR_VERSION = '2.3.2'
> -- Boost include: D:/Install/Libraries/BOOST/boost_1_37_0
> -- Boost libraries:
> optimized;D:/Install/Libraries/BOOST/boost_1_37_0/lib/libboost_th
> st_1_37_0/lib/libboost_thread-vc90-mt-gd-1_37.lib
> -- Boost definitions:
> -- USING BOOST_VERSION = '1.37.0'
> -- CMAKE_INSTALL_PREFIX=P:/Program Files (x86)/CGAL
> -- Configuring done
> -- Generating done
> -- Build files have been written to: P:/Program Files (x86)/CGAL-3.4
> Seems there something odd? I have previously disabled Qt3 and Qt4.
> Regards,
> Tom
> Fernando Cacciola schrieb:
>> Hi Tom,
>>> Hi Fernando,
>>> thanks for your answer. Why do you think I used the old installer
>>> system?
>> Because of this:
>>>>> $(CGALROOT)\include
>>>>> $(CGALROOT)\auxiliary\gmp\include
>>>>> $(BOOSTROOT)
>>>>> And my Linker-Dirs are:
>>>>> $(CGALROOT)\lib
>>>>> $(CGALROOT)\auxiliary\gmp\lib
>>>>> $(BOOSTROOT)\lib
>> That doesn't look quite like the set of directories that a project
>> file generated via CMake would contain.
>> In fact, it looks exactly like the setup used in CGAL 3.3.1
>> Could those be in your gobal IDE settings rather than the cmake
>> generated solution?
>> In windows, the gmp libs (which are producing your linker errors) are
>> auto-linked, but the libs directory must be correct.
>>> So what could it be else?
>> Can you post the output from cmake just to be sure there is nothing
>> odd going on?
>> HTH
>> Fernando Cacciola
>> www.geometryfactory.com
- [cgal-discuss] Jet_fitting_3, Priyamvad Deshmukh, 03/05/2009
- Re: [cgal-discuss] Jet_fitting_3, naresh, 03/05/2009
- Re: [cgal-discuss] Jet_fitting_3, Andreas Fabri, 03/05/2009
- [cgal-discuss] Linker errors in CGAL 3.4 examples?, Tom Kazimiers, 03/05/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Fernando Cacciola, 03/05/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Tom Kazimiers, 03/05/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Tom Kazimiers, 03/06/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Tom Kazimiers, 03/07/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Mahmood Naderan, 03/08/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Tom Kazimiers, 03/08/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Fernando Cacciola, 03/09/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Tom Kazimiers, 03/10/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Fernando Cacciola, 03/10/2009
- Re: [cgal-discuss] Jet_fitting_3, Priyamvad Deshmukh, 03/05/2009
- [cgal-discuss] Triangulation of a Polygon_with_holes_2 without introducing Steiner points, BBB HHH, 03/05/2009
- Re: [cgal-discuss] Triangulation of a Polygon_with_holes_2 without introducing Steiner points, Laurent Rineau (GeometryFactory), 03/05/2009
