cgal-discuss - Re: [cgal-discuss] Interval Skip List in x-y-direction
  • To:
  • Subject: Re: [cgal-discuss] Interval Skip List in x-y-direction
  • Date: Mon, 09 Mar 2009 19:02:43 +0100
wrote:
Hi,
i was wondering if there is a way to implement an Interval Skip List for faces
in a triangulation based on an x-y interval from another point (lets say p1)
that is not included in the triangulation?
I'm calculate a delaunay_triangulation_2 of a terrain and have another point
that is not in the triangulation itself but within the convex hull of the
terrain. Now i would like to search for the face/triangle in which the p1
would
fall in the plane view of the triangulation. Currently i'm checking each
triangle (only in x-y) if it contains p1 in it (i do that with a point in
polygon check). The problem is i have to loop through each triangle to find a
"match". I would like to reduce the possible triangle candidates by an
Interval
Skip List.
Hope i explained this in an understable way...
You mean, given a triangulation with 3D points, but the projection traits
class
you want for a point p=(x,y) locate the face on that p gets vertically
projected.
The method Triangulation_2::locate(Point) does exactly that, but maybe you
want to do something more elaborate.
andreas
