cgal-discuss - Re: [cgal-discuss] Interval Skip List in x-y-direction
  • To:
  • Subject: Re: [cgal-discuss] Interval Skip List in x-y-direction
  • Date: Mon, 09 Mar 2009 20:12:35 +0100
wrote:
Hi Andreas,
that seems to be an appropriate solution. However I don't get it to work. Does
locate only works for Triangulation_2 or also for Delaunay_Triangulation_2 ? I
get an error "no matching function" when trying this:
Point2 p_c(2.0,3.2);
Face_handle fh = Delaunay.locate(p_c);
Hi Matthias,
Well, if you use the traits class that allows you to insert 3D points,
and only their x and y coordinate is taken into account, you should also use
DT::Point p(2.0, 3.2, 0);
When it works, you should next have a look at
http://www.cgal.org/Manual/3.4/doc_html/cgal_manual/Triangulation_2/Chapter_main.html#Section_29.10
The thing is that with the locate function you get it down from linear
time (looking at all triangles) to sqrt(n) time (the average diameter of
a triangulation with n vertices and random points in a square).
The Triangulation_hierarchy_2 brings it down to log(n).
andreas
