- To:
- Subject: [cgal-discuss] possible bug: surface mesher got trapped
- Date: Wed, 11 Mar 2009 17:23:58 -0400
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:user-agent:mime-version:to:subject :content-type; b=r8DcO3hJ7WUm8X7KxKZ2QpDb0nL8Qho5HEXcfcV/3LuSwyeA0cTMW4ipkADsQn4Fu5 70U2KJtEELCSUH8y5KQ6Ofryu153lEguLZfJz6fQmSdQJtJKUwzVsyPORJqwpno33I3b hmggBRh/WFeLXgnCzXGUNjsGiQVyVYauyOPtU=
The attached zip file contains a 3D binary image stored in INR format.
I found that CGAL surface mesher produced strange results with this dataset.
By using a threadhold value=0.5, bounding sphere center=(122.0, 82.0, 93.0),
radius^2=32258, and CGAL::Surface_mesh_default_criteria_3<Tr> criteria(30,4,4),
I run the mesh_a_3d_gray_image example with this data, and unfortunately,
the program had ran forever and exhausted the system memory.
Then I modified include/CGAL/Surface_mesher/Surface_mesher.h
void refine_mesh(Visitor visitor) function and set a termination condition
when tr.number_of_vertices() reaches certain number. If I set this
number be 40000, I got some reasonable surface mesh output.
However, if I make the limit bigger, say 80000, the program will return
a mesh with similar mesh density. Plotting the nodes, I found that there
are huge number of them aggregate around coordinates (39 93 86);
a plot for all the nodes between two narrow planes x=38.8 and x=39.6
is shown in the attached figure (note the x-axis span is indeed very small).
From the plot, it looks like the mesh refinement was trapped near this mentioned
position and new points were added in a straight line fashion.
I am curious if this is an expected behavior. I know setting the angular bound
may cause some troubles for certain structures, but I don't know if this
straight-line trapping is one of those.
your comments are appreciated.
Qianqian
pre_extract.zip
Description: Binary data
- [cgal-discuss] possible bug: surface mesher got trapped, Qianqian Fang, 03/11/2009
- Re: [cgal-discuss] possible bug: surface mesher got trapped, Laurent Rineau (GeometryFactory), 03/11/2009
- Re: [cgal-discuss] possible bug: surface mesher got trapped, Qianqian Fang, 03/12/2009
