cgal-discuss - Re: [cgal-discuss]  Another question regardin Nef polyhedra  - shalfedges
  • To:
  • Subject: Re: [cgal-discuss]  Another question regardin Nef polyhedra  - shalfedges
  • Date: Fri, 13 Mar 2009 11:21:36 +0200
Ok, I see. So all shalfedges are inside spheremaps, and the spheremaps connect
to each other on a face using next() and prev(). What I didn't understand
earlier, is that the edge-uses are not represented explicitly, but as a next()
move from one spheremap to another.
Thanks.
Amir.
Quoting Peter Hachenberger
> There is only one type shalfedges and it includes the following
> handles(pointers):
> class SHalfedge{...SHalfedge_handle next;SHalfedge_handle
> prev;SHalfedge_handle snext;SHalfedge_handle sprev;...};
> The latter two pointers navigate on a sphere map. So if you have a cube
> andyou have the shalfedge of the sphere map of the vertex in the lower left
> frontcorner that belongs to the lower facet of the cube, then the
> snext-handle pointsto a shalfedge on the same sphere map that belongs to the
> front face of the cube.Likewise, the sprev-handle points to a shalfedge on
> the same sphere map that belongsto the left facet of the cube. The next and
> the prev handle both point to shalfedgesof that belong to the lower facet of
> the cube---on of them is on the sphere mapof the lower left back corner and
> the other is on the sphere map of the lower right frontcorner.
> Peter -----
> wrote: -----
> To:
> From:
> Date: 03/12/2009 12:35AM
> shalfedges
> so.. the edge-uses, are they data-typed as shalfedges? if so, then these are
> "shalfedges" which are not on the spheremap, no?
> > Hi Amir,
> > you got that a bit wrong. Every shalfedge is on a sphere map. SHalfedges
> > occurr
> > in two types of cycles in cycles around sfaces on a sphere map and in
> > halffacet cycles.
> > In the latter case we call the traversing of the shalfedges an edge-use.
> > Peter
> > -----"Amir Vaxman"
> > wrote: -----
> > To:
> > From: "Amir Vaxman"
> > Date: 03/11/2009 02:17PM
> > Subject: [cgal-discuss] Another question regardin Nef polyhedra -
> shalfedges
> > Hello,
> > If I understand correctly, when I traverse a halffacet
> > cycle, I get a cyclic list of shalfedges. I gatherd that every other
> > shalfedge
> > is on the spheremap of a vertex (and the others are what is called
> > â€&#65533;oriented
> > edge-useâ€&#65533;). How do I know which is which?
> > Amir.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
