- To: Camille Wormser <>, <>
- Subject: Re: [cgal-discuss] help with CGAL conceptual
- Date: Fri, 13 Mar 2009 01:54:01 -0500
Hi guys,
I am Khuong, a newbie in CGAL. I'd like to ask you
about some details in the CGAL library
1. Where can I find the manual reference for
X_handle (e.g, Face_handle, Vertex_handle...). For example, in the
implementation examples/Segment_Delaunay_graph_2/sdg-voronoi-edges.cpp,
the author called function site() SDG2::Vertex_handle, but I couldn't find any
reference to SDG2::Vertex_handle.
2. I couldn't find the detail about the manual
reference of the Segment_Delaunay_graph_2::Edge (and Edge object in general).
For example, in the same file above, the author call e.first, e.second....No
reference found either!!!
3. I'd like to extract the faces with associated
edges of the segment voronoi diagram. Could you guy tell me how to proceed? I'm
completely lost in the CGAL's manual reference!!!
Looking forward to your response. I truly
appreciate your help!
Khuong
----- Original Message -----
To: <>
Sent: Monday, October 27, 2008 5:07 PM
conceptual
> be
> accessed threw handlers, iterators and circulators.
> Still have a question: How do I create/get edge_handler from a facet?
Here is what the Triangulation_data_structure_3 manual says:
> typedef Triple<Cell_handle, int, int> Edge;
> (c,i,j) is the edge of cell c whose vertices indices are i and j.
> (See Section 28.1.)
> typedef std::pair<Cell_handle, int> Facet;
> (c,i) is the facet of c opposite to the vertex of index i. (See
> Section 28.1.)
In your code, you would access the Cell_handle and the index from the
Facet_iterator facet by doing
Cell_handle c = facet->first;
int index = facet->second;
Camille
- Re: [cgal-discuss] help with CGAL conceptual, Khuong Vu, 03/13/2009
- Re: [cgal-discuss] help with CGAL conceptual, Ashwin Nanjappa, 03/18/2009
- RE: [cgal-discuss] help with CGAL conceptual, Vu, Khuong, 03/18/2009
