cgal-discuss - RE: [cgal-discuss]  Nef Polyhedron Iteration
  • To:
  • Subject: RE: [cgal-discuss]  Nef Polyhedron Iteration
  • Date: Mon, 16 Mar 2009 11:13:04 +0100
  • Importance: Normal
  • Sensitivity:
Yes, you are right. I'm not even sure whether that's in the documentation. I
should look that up. The first volume, i.e., N.volumes_begin(), is always the
outer volume. Also, in the list of shells of a volume, the first one is always the
enclosing shell. In case of the outer volume, there is no outer shell.
Peter
-----"Amir Vaxman" <> wrote: -----
To: <>
Date: 03/15/2009 01:56PM
I’m sorry to bother, but I don’t see how in shell_exploration.cpp (which computes the minimal vertex) I get to see which of the shells is the outer shell (and in 2D, I also want to know which of the cycles is the outer cycle of a facet). Do these happen to be the first facet cycle/shell in the respective iterations?
Thanks,
Amir.
Sent: Wednesday, March 11, 2009 6:58 PM
To:
Subject: Re: [cgal-discuss] Nef Polyhedron Iteration
Look into the example programs. I made one for most of these
cases. Your first question is answered by shell_exploration.cpp
Peter
To: <>
Date: 03/11/2009 12:25PM
Subject: [cgal-discuss] Nef Polyhedron Iteration
Hello,
How do I iterate on the shells of a given volume, knowing which is the outer shell and which are holes? Furthermore, how do I get a  halffacet of every shell?
Amir.
