cgal-discuss - Antwort: Re: Antwort: Re: AW: Re: [cgal-discuss] install cgal 3.4 devian
  • To:
  • Subject: Antwort: Re: Antwort: Re: AW: Re: [cgal-discuss] install cgal 3.4 devian
  • Date: Mon, 16 Mar 2009 11:08:36 +0100
Hi,
I could clean an built the main project, but when running I get this message:
terminate called after throwing an instance of 'CGAL::Assertion_exception'
  what():  CGAL ERROR: assertion violation!
Expr: -CGAL_IA_MUL(-1.1, 10.1) != CGAL_IA_MUL(1.1, 10.1)
File: /usr/include/CGAL/Interval_nt.h
Line: 154
Explanation: Wrong rounding: did you forget the -frounding-math option if you use GCC?
/usr/local/netbeans-6.5/cnd2/bin/dorun.sh: line 103: 25321 Abgebrochen             "$pgm" "$@"
I have no idea how to proceed. Tx
Engineering Center Steyr GmbH & Co KG
Geschaeftsfuehrende Gesellschaft: Engineering Center Steyr GmbH
Geschaeftsfuehrer der geschaeftsfuehrenden Gesellschaft: Dipl. Ing. Franz Dorfer
Sitz der geschaeftsfuehrenden Gesellschaft: 4300 St. Valentin, Oesterreich
Firmenbuchgericht: St. Poelten / FN 140816h
Sitz der Gesellschaft: 4300 St. Valentin, Steyrer Strasse 32, Oesterreich
Firmenbuchgericht: St. Poelten / FN 222001y
CONFIDENTIALITY NOTE: This message contains information which may be privileged or confidential, or exempt from disclosure under applicable law. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering the message to the intended recipient, you are hereby notified that any dissemination, distribution, retention, archiving, or copying of this communication is strictly prohibited. If you have received this e-mail in error, please notify us immediately by return e-mail to the sender of this message.
