- To:
- Subject: Re: [cgal-discuss] 2D Apollonius Graphs
- Date: Mon, 16 Mar 2009 12:41:23 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type:content-transfer-encoding; b=xp2CFxO6KMR2LocF4hO10iyvl3AUgtdTHPkAo892Mx4xr/BCNM2srdlUnnvfzwGgY5 Dy/yAH+xrU0HmJw7iqHsmSv55fFkbAmyS2VGpDH2Bz5s/Q63u3D2uGqIAvI69piVty1g 3SQZXrukxrWKNoPVtc9wbUC6IykWQdyPa6fB0=
Hi Andreas,
thank you for your comment. It is good to know that I'm not missing
something essential.
I'm working on so-called "capacity-constrained Voronoi tessellation",
which are weighted Voronoi tessellations with pre-defined region
areas, e.g. 10 sites in a polygon of area 1, where each Voronoi region
has an area of 0.1. The weights of the sites allow to control the
region areas throughout an iterative optimization. I use the resulting
tessellations in different areas of computer graphics and
visualization.
Michael
On Mon, Mar 16, 2009 at 12:10, Andreas Fabri
wrote:
> Hi Michael, Hi Zhan,
> It would be best if you explain what you expect. The edges are
> hyperbola arcs, so you are on the right track by looking at
> the hyperbola class. It is not documented as it is not in
> the CGAL kernel concept. The endpoints of the hyperbola arcs
> are only given implicitely, that is you can get the sites
> (circles) which are equidistant to the Voronoi vertex.
> For the unbounded Voronoi cells they have linear rays at the
> two "ends" (unless your input consists of only two disks.
> Hope this helps,
> andreas
> ps.: Just out of curiosity: What problem do you want to solve
> with the Voronoi diagram of disks ?
> Michael Balzer wrote:
>> Hi,
>> I'm currently working on the same problem (for the third time):
>> extracting the regions of the Apollonius diagram from the underlying
>> Apollonius graph. I'm either too stupid for it, or it's really tricky
>> with CGAL (probably it's the first of the two alternatives).
>> My first approach some years ago was to use the method
>> draw_dual_edge(Edge e, Stream& str) of Apollonius_graph_2 for which I
>> implemented my own special stream class. It worked, but I had major
>> problem to create the complete polygons for a regions du to the fact
>> that this method just draw the edges with no particular scheme that
>> allows me too know their orientation and order in the resulting
>> polygon.
>> My second approach was to utilize the CGAL classes Hyperbola_2 and its
>> derivatives. They are not in the manual, but used by the Apollonius
>> classes and not hard to understand. With the edge traversal around an
>> Apollonius site and my own hyperbola classes based on Hyperbola_2 I
>> built my polygonal regions. This approach worked much better, but I
>> still had some problems, especially with the infinite regions.
>> I would really appreciate to get a comment from one of the CGAL
>> auhtors on this topic of extracting the polygonal regions of an
>> Apollonius diagram from the underlying Apollonius graph. Is there
>> something I overlook, or another CGAL package that provides a solution
>> to this problem. I as well tried the Voronoi_diagram_2 adaptor class
>> but could not get a sufficient result for others than the normal
>> Delauney graph.
>> Kind regards,
>> Michael
>> On Fri, Mar 13, 2009 at 15:30, Gao Zhan, Jimmy
>> wrote:
>>> Hello CGAL friends
>>> I want to use the 2D Apollonius Graphs module to obtain the voronoi
>>> diagram
>>> of some disks on a plane. My question is how to get the edge information?
>>> What’s the geometric representation of the edges? I can get the edge
>>> iterator, but after that how do I get the information?
>>> Any suggestion or hints are appreciated.
>>> Best,
>>> Zhan
>>> You are currently subscribed to cgal-discuss.
>>> To unsubscribe or access the archives, go to
>>> https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] 2D Apollonius Graphs, Gao Zhan, Jimmy, 03/13/2009
- Re: [cgal-discuss] 2D Apollonius Graphs, Michael Balzer, 03/16/2009
- Re: [cgal-discuss] 2D Apollonius Graphs, Andreas Fabri, 03/16/2009
- Re: [cgal-discuss] 2D Apollonius Graphs, Gao Zhan, Jimmy, 03/16/2009
