- To:
- Subject: Re: [cgal-discuss] 2D Apollonius Graphs
- Date: Mon, 16 Mar 2009 14:33:15 +0100
Bonjour Andreas
Thanks for your suggestion and reminder.
For me, I need to generate a safe 2D path for nano manipulation path planner. I need to create a graph and then use it to obtain the shortest path.
best,
Zhan
Andreas Fabri wrote:
Hi Michael, Hi Zhan,
It would be best if you explain what you expect. The edges are
hyperbola arcs, so you are on the right track by looking at
the hyperbola class. It is not documented as it is not in
the CGAL kernel concept. The endpoints of the hyperbola arcs
are only given implicitely, that is you can get the sites
(circles) which are equidistant to the Voronoi vertex.
For the unbounded Voronoi cells they have linear rays at the
two "ends" (unless your input consists of only two disks.
Hope this helps,
andreas
ps.: Just out of curiosity: What problem do you want to solve
with the Voronoi diagram of disks ?
Michael Balzer wrote:
Hi,
I'm currently working on the same problem (for the third time):
extracting the regions of the Apollonius diagram from the underlying
Apollonius graph. I'm either too stupid for it, or it's really tricky
with CGAL (probably it's the first of the two alternatives).
My first approach some years ago was to use the method
draw_dual_edge(Edge e, Stream& str) of Apollonius_graph_2 for which I
implemented my own special stream class. It worked, but I had major
problem to create the complete polygons for a regions du to the fact
that this method just draw the edges with no particular scheme that
allows me too know their orientation and order in the resulting
polygon.
My second approach was to utilize the CGAL classes Hyperbola_2 and its
derivatives. They are not in the manual, but used by the Apollonius
classes and not hard to understand. With the edge traversal around an
Apollonius site and my own hyperbola classes based on Hyperbola_2 I
built my polygonal regions. This approach worked much better, but I
still had some problems, especially with the infinite regions.
I would really appreciate to get a comment from one of the CGAL
auhtors on this topic of extracting the polygonal regions of an
Apollonius diagram from the underlying Apollonius graph. Is there
something I overlook, or another CGAL package that provides a solution
to this problem. I as well tried the Voronoi_diagram_2 adaptor class
but could not get a sufficient result for others than the normal
Delauney graph.
Kind regards,
Michael
On Fri, Mar 13, 2009 at 15:30, Gao Zhan, Jimmy <> wrote:Hello CGAL friends
I want to use the 2D Apollonius Graphs module to obtain the voronoi diagram
of some disks on a plane. My question is how to get the edge information?
What’s the geometric representation of the edges? I can get the edge
iterator, but after that how do I get the information?
Any suggestion or hints are appreciated.
Best,
Zhan
- [cgal-discuss] 2D Apollonius Graphs, Gao Zhan, Jimmy, 03/13/2009
- Re: [cgal-discuss] 2D Apollonius Graphs, Michael Balzer, 03/16/2009
- Re: [cgal-discuss] 2D Apollonius Graphs, Andreas Fabri, 03/16/2009
- Re: [cgal-discuss] 2D Apollonius Graphs, Gao Zhan, Jimmy, 03/16/2009
