- To: <>
- Subject: Re: [cgal-discuss] To Fernando: my code and errors for SVD
- Date: Tue, 17 Mar 2009 12:01:08 -0500
Hi Fernando and Manuel,
Thanks for your help. I think I found the wrong thing of my code.
Khuong
----- Original Message ----- From: "Vu, Khuong" <>
To:
Cc:
Sent: Monday, March 16, 2009 2:46 PM
Subject: [cgal-discuss] To Fernando: my code and errors for SVD
Hi Fernando,
Below are my code (I modified a bit) and the errors. I just post the part that I think important. I guess the TAGs I used were not valid for segment VD. I truly appreciate your help!!!
Khuong
#include <CGAL/basic.h>
// standard includes
#include <iostream>
#include <fstream>
#include <cassert>
// define the exact number type
# include <CGAL/Quotient.h>
# include <CGAL/MP_Float.h>
typedef CGAL::Quotient<CGAL::MP_Float> ENT;
// define the kernels
#include <CGAL/Simple_cartesian.h>
typedef CGAL::Simple_cartesian<double> CK;
typedef CGAL::Simple_cartesian<ENT> EK;
// typedefs for the traits and the algorithm
#include <CGAL/Segment_Delaunay_graph_filtered_traits_2.h>
#include <CGAL/Segment_Delaunay_graph_2.h>
#include <CGAL/Voronoi_diagram_2.h>
#include <CGAL/Segment_Delaunay_graph_adaptation_traits_2.h>
#include <CGAL/Segment_Delaunay_graph_traits_2.h>
#include <CGAL/Segment_Delaunay_graph_adaptation_policies_2.h>
typedef CGAL::Segment_Delaunay_graph_filtered_traits_2<CK,
/* The construction kernel allows for / and sqrt */ CGAL::Field_with_sqrt_tag,
EK,
/* The exact kernel supports field ops exactly */ CGAL::Field_tag> Gt;
typedef CGAL::Segment_Delaunay_graph_2<Gt> SDG2;
typedef CGAL::Segment_Delaunay_graph_degeneracy_removal_policy_2<SDG2> AP;
typedef CGAL::Segment_Delaunay_graph_adaptation_traits_2<SDG2> AT;
typedef CGAL::Voronoi_diagram_2<SDG2, AP, AT> VD;
typedef AT::Site_2 Site_2;
using namespace std;
int main() {
ifstream ifs("data/sitesx.cin");
assert( ifs );
Site_2 site;
VD vd;
while ( ifs >> site ) { vd.insert( site ); }
ifs.close();
assert( vd.is_valid() );
cout << endl << endl;
return 0;
my-finding-vertices.cpp:53: instantiated from here
/usr/include/CGAL/Voronoi_diagram_2/Iterator_adaptors.h:182: error: ‘const class CGAL::Vd2<CGAL::Sdg2<CGAL::Sdgft2<CGAL::Simple_cartesian<double>, CGAL::Field_with_sqrt_tag, CGAL::Simple_cartesian<CGAL::Quotient<CGAL::MP_Float> >, CGAL::Field_tag, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::Field_with_sqrt_tag, CGAL::Cartesian_converter<CGAL::Simple_cartesian<double>, CGAL::Simple_cartesian<CGAL::Quotient<CGAL::MP_Float> >, CGAL::NT_converter<double, CGAL::Quotient<CGAL::MP_Float> > >, CGAL::Cartesian_converter<CGAL::Simple_cartesian<double>, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::To_interval<double> > >, CGAL::Segment_Delaunay_graph_storage_traits_2<CGAL::Sdgft2<CGAL::Simple_cartesian<double>, CGAL::Field_with_sqrt_tag, CGAL::Simple_cartesian<CGAL::Quotient<CGAL::MP_Float> >, CGAL::Field_tag, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::Field_with_sqrt_tag, CGAL::Cartesian_converter<CGAL::Simple_cartesian<double>, CGAL::Simple_cartesian<CGAL::Quotient<CGAL::MP_Float> >, CGAL::NT_converter<double, CGAL::Quotient<CGAL::MP_Float> > >, CGAL::Cartesian_converter<CGAL::Simple_cartesian<double>, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::To_interval<double> > > >, CGAL::Tds2<CGAL::Sdgvb2<CGAL::Segment_Delaunay_graph_storage_traits_2<CGAL::Sdgft2<CGAL::Simple_cartesian<double>, CGAL::Field_with_sqrt_tag, CGAL::Simple_cartesian<CGAL::Quotient<CGAL::MP_Float> >, CGAL::Field_tag, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::Field_with_sqrt_tag, CGAL::Cartesian_converter<CGAL::Simple_cartesian<double>, CGAL::Simple_cartesian<CGAL::Quotient<CGAL::MP_Float> >, CGAL::NT_converter<double, CGAL::Quotient<CGAL::MP_Float> > >, CGAL::Cartesian_converter<CGAL::Simple_cartesian<double>, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::To_interval<double> > > >, CGAL::Tdsvb<void> >, CGAL::Tfb<CGAL::Sdgft2<CGAL::Simple_cartesian<double>, CGAL::Field_with_sqrt_tag, CGAL::Simple_cartesian<CGAL::Quotient<CGAL::MP_Float> >, CGAL::Field_tag, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::Field_with_sqrt_tag, CGAL::Cartesian_converter<CGAL::Simple_cartesian<double>, CGAL::Simple_cartesian<CGAL::Quotient<CGAL::MP_Float> >, CGAL::NT_converter<double, CGAL::Quotient<CGAL::MP_Float> > >, CGAL::Cartesian_converter<CGAL::Simple_cartesian<double>, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::To_interval<double> > >, CGAL::Tdsfb<void> > >, CGAL::Boolean_tag<false> >, CGAL::Segment_Delaunay_graph_degeneracy_removal_policy_2<CGAL::Sdg2<CGAL::Sdgft2<CGAL::Simple_cartesian<double>, CGAL::Field_with_sqrt_tag, CGAL::Simple_cartesian<CGAL::Quotient<CGAL::MP_Float> >, CGAL::Field_tag, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::Field_with_sqrt_tag, CGAL::Cartesian_converter<CGAL::Simple_cartesian<double>, CGAL::Simple_cartesian<CGAL::Quotient<CGAL::MP_Float> >, CGAL::NT_converter<double, CGAL::Quotient<CGAL::MP_Float> > >, CGAL::Cartesian_converter<CGAL::Simple_cartesian<double>, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::To_interval<double> > >, CGAL::Segment_Delaunay_graph_storage_traits_2<CGAL::Sdgft2<CGAL::Simple_cartesian<double>, CGAL::Field_with_sqrt_tag, CGAL::Simple_cartesian<CGAL::Quotient<CGAL::MP_Float> >, CGAL::Field_tag, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::Field_with_sqrt_tag, CGAL::Cartesian_converter<CGAL::Simple_cartesian<double>, CGAL::Simple_cartesian<CGAL::Quotient<CGAL::MP_Float> >, CGAL::NT_converter<double, CGAL::Quotient<CGAL::MP_Float> > >, CGAL::Cartesian_converter<CGAL::Simple_cartesian<double>, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::To_interval<double> > > >, CGAL::Tds2<CGAL::Sdgvb2<CGAL::Segment_Delaunay_graph_storage_traits_2<CGAL::Sdgft2<CGAL::Simple_cartesian<double>, CGAL::Field_with_sqrt_tag, CGAL::Simple_cartesian<CGAL::Quotient<CGAL::MP_Float> >, CGAL::Field_tag, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::Field_with_sqrt_tag, CGAL::Cartesian_converter<CGAL::Simple_cartesian<double>, CGAL::Simple_cartesian<CGAL::Quotient<CGAL::MP_Float> >, CGAL::NT_converter<double, CGAL::Quotient<CGAL::MP_Float> > >, CGAL::Cartesian_converter<CGAL::Simple_cartesian<double>, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::To_interval<double> > > >, CGAL::Tdsvb<void> >, CGAL::Tfb<CGAL::Sdgft2<CGAL::Simple_cartesian<double>, CGAL::Field_with_sqrt_tag, CGAL::Simple_cartesian<CGAL::Quotient<CGAL::MP_Float> >, CGAL::Field_tag, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::Field_with_sqrt_tag, CGAL::Cartesian_converter<CGAL::Simple_cartesian<double>, CGAL::Simple_cartesian<CGAL::Quotient<CGAL::MP_Float> >, CGAL::NT_converter<double, CGAL::Quotient<CGAL::MP_Float> > >, CGAL::Cartesian_converter<CGAL::Simple_cartesian<double>, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::To_interval<double> > >, CGAL::Tdsfb<void> > >, CGAL::Boolean_tag<false> > >, CGAL::Sdgat2<CGAL::Sdg2<CGAL::Sdgft2<CGAL::Simple_cartesian<double>, CGAL::Field_with_sqrt_tag, CGAL::Simple_cartesian<CGAL::Quotient<CGAL::MP_Float> >, CGAL::Field_tag, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::Field_with_sqrt_tag, CGAL::Cartesian_converter<CGAL::Simple_cartesian<double>, CGAL::Simple_cartesian<CGAL::Quotient<CGAL::MP_Float> >, CGAL::NT_converter<double, CGAL::Quotient<CGAL::MP_Float> > >, CGAL::Cartesian_converter<CGAL::Simple_cartesian<double>, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::To_interval<double> > >, CGAL::Segment_Delaunay_graph_storage_traits_2<CGAL::Sdgft2<CGAL::Simple_cartesian<double>, CGAL::Field_with_sqrt_tag, CGAL::Simple_cartesian<CGAL::Quotient<CGAL::MP_Float> >, CGAL::Field_tag, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::Field_with_sqrt_tag, CGAL::Cartesian_converter<CGAL::Simple_cartesian<double>, CGAL::Simple_cartesian<CGAL::Quotient<CGAL::MP_Float> >, CGAL::NT_converter<double, CGAL::Quotient<CGAL::MP_Float> > >, CGAL::Cartesian_converter<CGAL::Simple_cartesian<double>, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::To_interval<double> > > >, CGAL::Tds2<CGAL::Sdgvb2<CGAL::Segment_Delaunay_graph_storage_traits_2<CGAL::Sdgft2<CGAL::Simple_cartesian<double>, CGAL::Field_with_sqrt_tag, CGAL::Simple_cartesian<CGAL::Quotient<CGAL::MP_Float> >, CGAL::Field_tag, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::Field_with_sqrt_tag, CGAL::Cartesian_converter<CGAL::Simple_cartesian<double>, CGAL::Simple_cartesian<CGAL::Quotient<CGAL::MP_Float> >, CGAL::NT_converter<double, CGAL::Quotient<CGAL::MP_Float> > >, CGAL::Cartesian_converter<CGAL::Simple_cartesian<double>, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::To_interval<double> > > >, CGAL::Tdsvb<void> >, CGAL::Tfb<CGAL::Sdgft2<CGAL::Simple_cartesian<double>, CGAL::Field_with_sqrt_tag, CGAL::Simple_cartesian<CGAL::Quotient<CGAL::MP_Float> >, CGAL::Field_tag, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::Field_with_sqrt_tag, CGAL::Cartesian_converter<CGAL::Simple_cartesian<double>, CGAL::Simple_cartesian<CGAL::Quotient<CGAL::MP_Float> >, CGAL::NT_converter<double, CGAL::Quotient<CGAL::MP_Float> > >, CGAL::Cartesian_converter<CGAL::Simple_cartesian<double>, CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::To_interval<double> > >, CGAL::Tdsfb<void> > >, CGAL::Boolean_tag<false> > > >’ has no member named ‘face_rejector’
make: *** [my-finding-vertices] Error 1
khuong@khuong-laptop:~/MyWork/kSVD$
- [cgal-discuss] To Fernando: my code and errors for SVD, Vu, Khuong, 03/16/2009
- Re: [cgal-discuss] To Fernando: my code and errors for SVD, Manuel Caroli, 03/16/2009
- Re: [cgal-discuss] To Fernando: my code and errors for SVD, Khuong Vu, 03/17/2009
