- To:
- Subject: [cgal-discuss] Circular Arrangements inexact?
- Date: Mon, 23 Mar 2009 15:57:21 +0100
Hi,
I am trying to compute exact circular arrangements with CGAL but even
with a simple example I run into trouble:
I use three circles at (0.01, 0.00), (-0.01, 0.00) and (0.00, 0.01) with
a radius of 0.01 each. Thus the circles intersect at (0.00, 0.00),
(0.01, 0.01) and (-0.01, 0.01). After computing the arrangement, I
iterate through the border (i.e. the halfedges) of each face and print
the source and target of each edge. Here I saw two things, that should
not happen with exact calculations:
First, there are edges which seem to have the same source and target,
but when comparing them with the appropriate equal-predicate they are
reported to be different. Secondly, e.g. instead of a location at (0.00,
0.00) a location at (0.00, -2.50766e-11) is reported.
Are the circular arrangements currently not implemented for exact
calculation or am I doing something wrong? (I am using the
CGAL::Exact_circular_kernel_2 and the CGAL::Arr_circle_segment_traits_2)
bye,
Dennis
Dennis Schieferdecker
Universität Karlsruhe (TH) | Fon : +49 (721) 608-6781
Institut für Theoretische Informatik | Fax : +49 (721) 608-3088
Am Fasanengarten 5, Zimmer 220 |
D-76131 Karlsruhe, Germany | Email:
- [cgal-discuss] Circular Arrangements inexact?, Dennis Schieferdecker, 03/23/2009
- Re: [cgal-discuss] Circular Arrangements inexact?, Ophir Setter, 03/23/2009
- Re: [cgal-discuss] Circular Arrangements inexact?, Dennis Schieferdecker, 03/24/2009
- Re: [cgal-discuss] Circular Arrangements inexact?, Efraim Fogel, 03/24/2009
- Re: [cgal-discuss] Circular Arrangements inexact?, Dennis Schieferdecker, 03/25/2009
- Re: [cgal-discuss] Circular Arrangements inexact?, Monique Teillaud, 03/25/2009
- Re: [cgal-discuss] Circular Arrangements inexact?, Dennis Schieferdecker, 03/31/2009
- Re: [cgal-discuss] Circular Arrangements inexact?, Sylvain Pion, 03/31/2009
