- To:
- Subject: Re: [cgal-discuss] Circular Arrangements inexact?
- Date: Tue, 24 Mar 2009 17:54:19 +0200
Dennis Schieferdecker wrote:
Ophir Setter schrieb:What operations are you missing?
The problem is probably that 0.01 is not translated to 1/100 in anThanks that did the trick (and significantly decreased the number of
exact manner.
You should construct 1/100 using a rational number constructor;
probably something like: Kernel::FT(1, 100).
faces with my larger setup). Maybe you could help me with another type
problem later in my program?
After having computed the circular arrangement, I need to perform
several calculations with the vertices of the arrangement. Unfortunately
the points they represent are of type Traits::Point_2 instead od
Kernel::Point_2 and use a different numerical type ( Traits::CoordNT,
i.e. one_root_number< Kermel::FT >). Here, I run into a problem, since I
cannot perform the typical operations I can with type Kernel::Point_2
and by converting Traits::Point_2 to Kernel::Point_2 I losse myThe traits supports curves that are either circular arcs or segments the coefficients of which are rational, and it contains a functor that computes the intersection between any pairs of curves supported by the traits. Intersections between segments the coefficients of which are not rational is not supported, at least not by the traits class.
exactness. In principle I need to compute the point that lies in the
middle of two vertices and the orientation of three vertices.
Also, a related problem is the compuatation of the intersection point of
one edge E of a face of the arrangement with a line L. Line L is defined
by two points of type Traits::Point_2 and Edge E is represented as
X_monotone_curve using a number type Traits::CoordNT. Now, the
intersection functor requires two lines of the same type. Thus I have to
represent line L as X_monotone_curve. Unfortunately, there is no way to
contruct one of two points of type Traits::Point_2, only of type
Kernel::Point_2.
Is there another (obvious) transformation I am missing, or are theThere are two traits that support circular arcs and segments in the arrangement package, namely, Arr_circle_segment_traits_2 and Arr_circular_line_arc_traits_2. The latter may support more operations, as it is based on a CircularKernel.
Traits::Point_2 the "end of the road" with regards to the reusability in
further calculations?
bye
Dennis
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
- [cgal-discuss] Circular Arrangements inexact?, Dennis Schieferdecker, 03/23/2009
- Re: [cgal-discuss] Circular Arrangements inexact?, Ophir Setter, 03/23/2009
- Re: [cgal-discuss] Circular Arrangements inexact?, Dennis Schieferdecker, 03/24/2009
- Re: [cgal-discuss] Circular Arrangements inexact?, Efraim Fogel, 03/24/2009
- Re: [cgal-discuss] Circular Arrangements inexact?, Dennis Schieferdecker, 03/25/2009
- Re: [cgal-discuss] Circular Arrangements inexact?, Monique Teillaud, 03/25/2009
- Re: [cgal-discuss] Circular Arrangements inexact?, Dennis Schieferdecker, 03/31/2009
- Re: [cgal-discuss] Circular Arrangements inexact?, Sylvain Pion, 03/31/2009
