- To:
- Subject: [cgal-discuss] segment fault of boolean 2D on 64 bit linux
- Date: Fri, 27 Mar 2009 03:48:03 +0100 (CET)
Hi,
Boolean operation with Polygon_set_2 or Nef_polyhedron_2 from CGAL-3.3.1 is
fine on 32 bit linux, but crashed on 64 bit. I use lazy_exact_nt<Gmpq> as
kernel. Is it possible that 64 bit compiled one is different from 32 bit one?
Would you tell me the possible causes? or Is there a way to catch this
exceptional case?
Thanks,
Hyungon Kim
- [cgal-discuss] segment fault of boolean 2D on 64 bit linux, hgkim, 03/27/2009
- Re: [cgal-discuss] segment fault of boolean 2D on 64 bit linux, Andreas Fabri, 03/27/2009
- Re: [cgal-discuss] segment fault of boolean 2D on 64 bit linux, Hyungon Kim, 03/27/2009
