cgal-discuss - Re: [cgal-discuss] segment fault of boolean 2D on 64 bit linux
  • To:
  • Subject: Re: [cgal-discuss] segment fault of boolean 2D on 64 bit linux
  • Date: Fri, 27 Mar 2009 09:38:33 +0100
wrote:
Hi,
Boolean operation with Polygon_set_2 or Nef_polyhedron_2 from CGAL-3.3.1 is
fine on 32 bit linux, but crashed on 64 bit. I use lazy_exact_nt<Gmpq> as
kernel. Is it possible that 64 bit compiled one is different from 32 bit one?
Would you tell me the possible causes? or Is there a way to catch this
exceptional case?
Thanks,
Hyungon Kim
It is rather astonishing that BOTH packages fail.
Can you send us a small test program and a data set in order to investigate.
Did you also check with CGAL 3.4
Best regards,
andreas
