- To:
- Subject: Re: [cgal-discuss] c2t3 question - finding the Delaunay traingulation
- Date: Mon, 30 Mar 2009 18:15:25 +0200
Most probably what is wanted here is a remesh of the input surface mesh Laurent Rineau (GeometryFactory) wrote: On Monday 30 March 2009 16:45:02 Sean McDuffee wrote:Hi, I'd like to input a surface mesh and compute it's Delaunay triangulation. It seems I should use Polyhedron_incremental_builder_3 for reading in the .obj file. This will fill out a Polyhedron_3. For a triangulation I guess I need to somehow insert this Poly data structure into a Delaunay_Triangulation_3 with the original Polyhedron_3 as a SurfaceMeshComplex_2InTriangulation_3 and then use the make_surface_mesh function to get a mesh I can output back to a .obj. Can someone tell me if this is the right track? I don't seem to know how to exactly put this together.You can compute the Delaunay triangulation of *a set of points*, and not from a surface mesh. Maybe your surface mesh is included in the triangulation, as a subset of facets, but that is not the general case. If you are sure that all the faces of your surface are a union of facets of the Delaunay triangulation of its vertices, then you can compute the Delaunay triangulation of the vertices of the surface, and then manually mark the surface in a c2t3. I do not see the interest. I think I have misunderstood your goal. -- Mariette Yvinec Geometrica project team INRIA Sophia-Antipolis |
- [cgal-discuss] c2t3 question - finding the Delaunay traingulation of, Sean McDuffee, 03/30/2009
- Re: [cgal-discuss] c2t3 question - finding the Delaunay traingulation of, Laurent Rineau (GeometryFactory), 03/30/2009
- Re: [cgal-discuss] c2t3 question - finding the Delaunay traingulation, Mariette Yvinec, 03/30/2009
- Re: [cgal-discuss] c2t3 question - finding the Delaunay traingulation, Sean McDuffee, 03/30/2009
- Re: [cgal-discuss] c2t3 question - finding the Delaunay traingulation, Sean McDuffee, 03/31/2009
